Qmodo's Avatar
Unhappy Cracked manifold on 2.2T
Hi guys
I have a 2.2l T engine in my 914. It's been mostly lots of fun. Lately I have had a lot of carb popping on one side and I was hoping it could be tuned out but my mechanic says I have a crack in my manifold on that side and therefore the popping. What are my options here? He didn't think it could be welded. If I need to buy a new part is that possible or should I be shopping for a used part. Any suggestions regarding getting good quality used parts would be helpful.
Martin
Old 05-11-2004, 06:26 PM
Navin Johnson
TimT's Avatar
you have a few options.. like having the crack welded closed, or step up and get a set of tall manifolds.... give a slight bump in the power dept..
'69 911 GT-5
'75 914 GT-3
and others
Old 05-11-2004, 07:48 PM
Navin Johnson
TimT's Avatar
If I still had mag manifolds and found a crack, Id open the crack up with a small round rasp... then fill the crack with some epoxy...
Im sure others will have better ideas
'69 911 GT-5
'75 914 GT-3
and others
Old 05-11-2004, 07:51 PM
Qmodo's Avatar
Smile The good news
Yes of course it can be welded and that's what I will do. Somehow I thought I would have to look for a replacement part.
Thanks guys.
Martin
Old 05-13-2004, 01:44 PM
Grady Clay's Avatar
I agree with TimT, epoxy. With the right epoxy, proper grinding a Vee, and proper cleaning/surface prep the repair can outlast the engine. Besides, it’s easy and cheap DIY.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 05-13-2004, 03:37 PM
