Send a message via ICQ to fly944
Pulled tensioner stud
Well, after timing my cams with the help of wonderful jgparker I incurred a little problem. After replacing my old idler arms with the updated parts I went to torque on my tensioners and the right tensioner stud pulled. What is the best fix? Can I install a helicoil with the chain still on the cam?
76 911 2.7
Old 05-11-2004, 06:30 PM
oneblueyedog's Avatar
A time cert might be better, but doesn't epoxy coat the back of the housing over the hole. If it does, you got to take care of that.
Lee 78SC
78SC coupe, Silver Metallic
Old 05-11-2004, 09:35 PM
Keep a shop vac running and sucking the aluminum chips while you ream the hole and tap it for the helicoil/timecert. Block off the hole where the chain comes into the housing with a lint free rag or tape it. Tilt the engine so the chips fall away from the case if the vacuum misses chips.
Old 05-11-2004, 09:46 PM
No Expert
jgparker's Avatar
It's probably an M8x1.25 stud. I wouldn't use a helicoil. I have that M8 timesert kit if you want to borrow it. The right side should be easy since it is below the chains.
JP
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 05-12-2004, 05:57 AM
