Poll: to compress or not to compress (as much), that is the question
Poll Options
adomakin's Avatar
So ive bought these 8.5-1 JEs.........
Right, Ive bought some 8.5-1 JEs. My 930 engine spec is as follows - 79 930 case, arp rod bolts, shot peened rods, 8.5-1 coated and dry filmed JE pistons, turbo studs, sc cams, K27, .9bar spring and the question is, what do I do- shim the barrels to bring the comp down to 7.5-1 or run it with 8.5-1? Im not going to be twin plugging, and ive got no idea how big my intercooler is going to be as my car is going to be a 73 SR replica with a duck tail. Yes i know, how the Łuck am i going to get an intercooler in there. well, you tell me!
Im thinking that i should probably reduce the comp to 7.5, what does anyone else think? oh, and sorry if I keep posting stuff about pistons and comp ratios vs boost but im gettingf confused as to what way i should go!!!!
Andy
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 05-11-2004, 09:56 PM
WydRyd's Avatar
I personaly like the idea of slightly lower compression and more boost. You'll make more power that way than running higher compression and less boost.
The SC Cams will improve pre-boost drivability anyway, so why run 8.5:1 C/R?
I say go for 7.5:1 @ 0.9-1.0bar. Make sure you have good intercooling tho, that's important!
Also, you'll be limited in how thick you can go with gaskets and shims without upsetting Cam Chain geometry. Use 0.5mm C2Turbo Head Gaskets for a better cylinder->head seal with 0.5mm Base Cylinder shims. It won't take you to 7.5:1. Perhaps 8.0:1. Get your mechanic to do all the appropriate measurements to determine exact C/R using these gaskets/shims.
Good luck!
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 05-11-2004, 11:12 PM
