nreed's Avatar
Help - valve spring height for elgin sc330 cam
Bruce Anderson's book recommends 34.5 as a valve spring height on both intake and exhaust. Is this correct for a 930 with elgin sc330's?
Also, the springs I have are wound closer on one end (more turns per inch). Does it matter how they are installed? I assume that the closer wound end goes to the head????
Thanks,
Norm '86 930
AEM Infinity 6 - Twin Plug 3.6L - DBW - JE Pistons/LN Eng. Cylinders - Pauter rods - GT3 Crank - GTX3584RS - ID1050x Injectors - Ported Intakes - Custom Intake Manifold, exhaust and intercooler - 993SS cams - ECUMASTER PMU-16DL
HRE Wheels 560R 8.5x18 ET25 (Front) 11x18 ET0 (Rear)
Old 05-13-2004, 07:55 PM
