-   -   Removing Carrera camshaft woodruf key? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/162849-removing-carrera-camshaft-woodruf-key.html)
Siena911 05-13-2004 09:44 AM
Removing woodruff key from camshafts.
In Wayne's rebuild book, it mentions to use a small screwdriver to carefully remove (pry out) the woodruff keys from the camshafts. Maybe it is just me but I could not get them out at all. I eventually had to tap it out using a small screwdriver.
How do you guys manage to get them out?
Are they meant to be that tight?
Will I have to apply force when I put it back together again?
Cheers Jakes
ischmitz 05-13-2004 09:57 AM
They are tight sometimes. I tapped mine out as well. Check the woodruff key for small burs and dress is with a fine file. The camshaft is hardened. So its slot should be fine.
Ingo
Wayne 962 05-13-2004 01:31 PM
Ingo is right - you should be fine. Sometimes tight, sometimes looser - depends upon wear factors, I suppose...
-Wayne
john walker's workshop 05-13-2004 02:04 PM
set a flat screwdriver tip right in behind it, horizontally, and tap with a hammer. it will roll right out of the keyway. try not to drop it into the engine.
vichang4 05-13-2004 04:51 PM
I had to use a set of channel lock pliers (wrapped with duct tape) to push my keys back into the cam. I used John Walker's method to remove them.
Vic
Siena911 05-14-2004 01:49 AM
Yep, thanks for the advice guys.
Now about that dropping it into the motor, yep I did that, Took me about half an hour to get the darned thing out!!!!
Jakes
oneblueyedog 05-14-2004 06:45 AM
On bank 1,2,3 I had to beat it out with a punch after boogering it up with:
a small screwdriver
needlenose pliers
vice grips.
The cam and shims survived but I had to get a new woodruff key. Not really a problem.
john walker's workshop 05-14-2004 07:58 AM
yes, large channel-locks for the install. don't forget to put the shims on first.
