Removing woodruff key from camshafts.
In Wayne's rebuild book, it mentions to use a small screwdriver to carefully remove (pry out) the woodruff keys from the camshafts. Maybe it is just me but I could not get them out at all. I eventually had to tap it out using a small screwdriver. How do you guys manage to get them out? Are they meant to be that tight? Will I have to apply force when I put it back together again? Cheers Jakes
If you want to run with the big dogs, you can't pee like a puppy!!! 92 Rover Metro 1.1 (54 manly horsepower) - Dont knock it it does 60 mpg!!! 81sc / 3.2 litre transplant (Broken BIG Time ) SCWDP deserter - HP junkie wannabe |
They are tight sometimes. I tapped mine out as well. Check the woodruff key for small burs and dress is with a fine file. The camshaft is hardened. So its slot should be fine.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Author of "101 Projects"
Ingo is right - you should be fine. Sometimes tight, sometimes looser - depends upon wear factors, I suppose...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
set a flat screwdriver tip right in behind it, horizontally, and tap with a hammer. it will roll right out of the keyway. try not to drop it into the engine.
I had to use a set of channel lock pliers (wrapped with duct tape) to push my keys back into the cam. I used John Walker's method to remove them.
Vic
Victor Toce 2000 Boxster S w/ Tequipment exhaust 1993 Spec Miata 87 911 turbo - sold 3.4 RUF pistons and cylinders Euro CIS head |
Yep, thanks for the advice guys.
Now about that dropping it into the motor, yep I did that, Took me about half an hour to get the darned thing out!!!! Jakes
On bank 1,2,3 I had to beat it out with a punch after boogering it up with:
a small screwdriver needlenose pliers vice grips. The cam and shims survived but I had to get a new woodruff key. Not really a problem.
78SC coupe, Silver Metallic |
yes, large channel-locks for the install. don't forget to put the shims on first.
