-   -   forgot lifting ring (http://forums.pelicanparts.com/911-engine-rebuilding-forum/163041-forgot-lifting-ring.html)
Damomma 05-14-2004 02:48 PM
forgot lifting ring
I presume it is ok to undo the one case bolt to install the lifting ring without jeopardizing the seal?
The case has been sealed and torqued for a couple of days but I forgot the ring.
john walker's workshop 05-14-2004 03:29 PM
do you need to lift the engine with it?
Damomma 05-14-2004 03:43 PM
Well I guess I don't have to but the ring is what I used to lift the fully dressed engine up to my engine stand and what I planned to use to get it back down to the floor.
From your question I am hearing that it is not a good idea. I was thinking that given that it was at the top I could get away with it?
Jamie
Fishcop 05-14-2004 04:46 PM
I would have thought loosening just that one nut for a short time wouldn't hurt.... But then again I'd defer to JWW :)
john walker's workshop 05-14-2004 05:04 PM
no problem with loosening the nut and putting the ring back on, i just didn't think anyone really used that ring, other than the factory.
Wayne 962 05-14-2004 05:57 PM
Right - no problem. It's not likely to leak from there anyways even if the seal is disturbed...
-Wayne
Damomma 05-14-2004 08:25 PM
OK now I have to ask, JW how do you lift the engine to put it on a stand?
magic930 05-14-2004 10:14 PM
I couldn't resist posting this after that last question! You don't see that every day in your average Porsche workshop!
http://forums.pelicanparts.com/uploa...1084601589.jpg
aigel 05-15-2004 01:07 AM
You put one chain on the engine stand yoke and two chains on the engine mount on the other side. That triangle will be a nice setup to lift the engine. Once it is on the ground or your dolly, you can take off the enigne stand yoke and you are all set.
George
jgparker 05-15-2004 05:39 AM
buy a bigger jack and a two legged stand. I've posted that pic too many times already.
john walker's workshop 05-15-2004 09:43 AM
i use a cherry picker and a 2" nylon woven strap. loop it around the bellhousing yolk, and around the motor mount crossbar. for engine only lifting, that factory loop is way off-center.
Wayne 962 05-15-2004 11:27 AM
Right - the engine hook is not designed to lift just the engine only - it's supposed to lift the engine and tranny together.
I personally just use my AC Hydraulic jack, which elevates the engine to engine-stand height quite easily!
http://www.pelicanparts.com/catalog/shopcart/TOOL/POR_TOOL_ACHyd1_pg1.htm
-Wayne
