cam sprocket dowel pin
I'm tearing down a '74 2.7L and just removed the large nut. Wayne's rebuild book says to simply remove the sprocket at this point. But it won't budge. Haynes says to remove the dowel pin using a bolt that you screw into it. What size bolt would this be? Thanks.
Charlie |
The thread of the small end of the spark plug threads perfect. thread it and pull. the dowell will come out.
Author of "101 Projects"
If you wiggle it, it should come out. The small pin doesn't really hold the sprocket in at all...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
That's what I thought, but it just won't budge. I spent an hour last night at it, and wiggled, pried, jimmied, all to no avail. So I thought maybe Haynes was right for once. Is it time to go out and buy a pulley-puller? I probably need one anyway.
Charlie |
Air Medal or two
hit for couple min with the propane.....someone may have glued it on with thir favorit stuffff
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
a small crowfoot prybar, or a angled brake adjuster spoon will persuade it off. a little on one side and a little on the other, repeat as necessary.
I got it off with a large rubber mallet and much vigouous shaking. I didn't want to get so physical with it yesterday, lest I break something. But with your'all advice, I figured I could go for it. Thanks.
Charlie |
Rubber mallet = sometimes man's best friend...
-Wayne
