Which is the correct washer for 2.7 head studs
Dear All,
when I disambled my engine I forgot to seperate the head studs washers. Which is the correct one. Here my choices. bob ![]() ![]() ![]() Here my project.
abit off center
The flat one with no chamfer.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Right, the one out and inside chamfer is for the case trough bolts. the flat one without chamfer is as Craig said, for the head studs. i'm in doubt about the last one.
Roslin
Porsche 911 SC 3.0 |
The square shoulder, chamfer inside is 65 to 73 through bolts
Bruce |
