Siena911's Avatar
Question Rod side to side movement?
Recently when I took the rods from my crank I pushed and pulled on the rods, I was surprised as to how much movement there was (in the direction of the crank length - if that makes sense).
I would have thought that it would be tighter than that.
Another thing, when eventually assembling the rods and inserting the wrist pins, does this place any strain on the bearing in any way, i.e. should I be very careful not to place any sideways stress on the rod?
Cheers Jakes
If you want to run with the big dogs, you can't pee like a puppy!!!
92 Rover Metro 1.1 (54 manly horsepower) - Dont knock it it does 60 mpg!!!
81sc / 3.2 litre transplant (Broken BIG Time )
SCWDP deserter - HP junkie wannabe
Old 05-26-2004, 04:30 AM
Home of the Whopper
A local engine builder told me he machines .003" off each side of stock rods.
Any comments?
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 05-26-2004, 03:03 PM
