-   -   CIS to Carb conversion - ? heads (http://forums.pelicanparts.com/911-engine-rebuilding-forum/164794-cis-carb-conversion-heads.html)
ber911 05-26-2004 02:44 AM
When I rebuild my motor, I am going to use Webbers instead of the CIS. Is it necessary to weld up the injector "pockets" at the top of the intake ports on the heads or can they be left as is?
Robert
jgparker 05-26-2004 10:22 AM
No, not really. I think this has been covered recenly.
jpnovak 05-26-2004 10:59 AM
You need to get the special riser gaskets that PMO sells. Covers them right up. Order them at the same time you buy the updated jetting materials.
Make sure to port match the manifolds to the SC heads. The weber manifolds are typically smaller in diameter.
Jamie
Wayne 962 05-26-2004 05:11 PM
Make sure that you upgrade to a more aggressive camshaft, otherwise there's not much point...
-Wayne
