CIS to Carb conversion - ? heads
When I rebuild my motor, I am going to use Webbers instead of the CIS. Is it necessary to weld up the injector "pockets" at the top of the intake ports on the heads or can they be left as is?
Robert
Old 05-26-2004, 02:44 AM
No Expert
jgparker's Avatar
No, not really. I think this has been covered recenly.
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 05-26-2004, 10:22 AM
I would rather be driving
jpnovak's Avatar
You need to get the special riser gaskets that PMO sells. Covers them right up. Order them at the same time you buy the updated jetting materials.
Make sure to port match the manifolds to the SC heads. The weber manifolds are typically smaller in diameter.
Jamie
Old 05-26-2004, 10:59 AM
