Cam timing changed ???
Hi,
So I rebuilt the top end of the engine & everyone seemed fine so far :) After my 1st track event (& ~500 miles total driving), I drained my oil, re-checked valve clearance, etc. just to make sure everything is ok after the break in period. While I'm at it, I re-checked my cam timing using the dial indicator. Because of location, I ended up checking cylinder #3 and #4. And that's the surprise - the value changed... I re-checked my cam timing, must be at least 5 times before I put the engine back into the car. They were 1.575. Now, #3 is at 1.31 and #4 is at 1.46 :confused: I supposed this can be due to chain slacks (when I checked/set timing, I used vise grip/tensioner per Wayne's book)? Just want to tap into the knowledgeable group here to see if this is normal & if my guess is right. Thanks... |
That's what you get for checking them again.
I don't think the chain tensioners apply enough pressure to make an accurate measurement. Using a different valve than the one you originally timed it with (#3 vs #1) probably introduces a little more error as well.
-Chris |
The tensioners do not apply enough pressure to the ilder arms. I just did this today. Timed cams in the morning and then tonite I figure I will check them one more time with only the tensioners in instead of a mechanical means to tighten the chains. Nearly crapped my shorts when my perfectly timed cams seemed to be out. Pulled a tensioner and went back to mechanical tensioning to check, and the timing is spot on!
Cheers, Jeff |
-Wayne |
Thanks for the confirmation guys... kinda what I was thinking as well.
The good news is that all my intake valves don't need adjustments :) It would have been a royal PITA to adjust cylinder #1 (which is why I checked the cam timing off #3 instead). Will continue my mission with the exhaust valves tonight. |
there is also some varation from the crank gear not comming around to the same chain link at every rotation when rechecking timing. it takes 9 revolutions to bring everything back to original start of gear and chain link.
Wow, you actually know it takes 9 revolutions :eek: Amazing!!!!
I did check the timing twice and they do change ever slightly each time (by ~.01mm). I thought that's operator's error but maybe its just the chain then... At this point, I'm kinda taking the noted & understood attitude. After many moons, I want to drive the car unless its really really bad |
It helps to thouroughly oil your chain before starting the process since the chain length will noticibly change depending on if its a little dry or loaded with oil.
I think this is a good example why any spec comes with a tolerance. What's the tolerance on this? I would not worry about it unless it is far outside the tolerance....
George |
| All times are GMT -8. The time now is 10:22 AM. |
