Hi,
So I rebuilt the top end of the engine & everyone seemed fine so far ![]() After my 1st track event (& ~500 miles total driving), I drained my oil, re-checked valve clearance, etc. just to make sure everything is ok after the break in period. While I'm at it, I re-checked my cam timing using the dial indicator. Because of location, I ended up checking cylinder #3 and #4. And that's the surprise - the value changed... I re-checked my cam timing, must be at least 5 times before I put the engine back into the car. They were 1.575. Now, #3 is at 1.31 and #4 is at 1.46 I supposed this can be due to chain slacks (when I checked/set timing, I used vise grip/tensioner per Wayne's book)? Just want to tap into the knowledgeable group here to see if this is normal & if my guess is right.Thanks...
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
That's what you get for checking them again.
72 Carrera RS replica, Spec 911 racer |
Irrationally exuberant
I don't think the chain tensioners apply enough pressure to make an accurate measurement. Using a different valve than the one you originally timed it with (#3 vs #1) probably introduces a little more error as well.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
The tensioners do not apply enough pressure to the ilder arms. I just did this today. Timed cams in the morning and then tonite I figure I will check them one more time with only the tensioners in instead of a mechanical means to tighten the chains. Nearly crapped my shorts when my perfectly timed cams seemed to be out. Pulled a tensioner and went back to mechanical tensioning to check, and the timing is spot on!
Cheers, Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Author of "101 Projects"
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Thanks for the confirmation guys... kinda what I was thinking as well.
The good news is that all my intake valves don't need adjustments It would have been a royal PITA to adjust cylinder #1 (which is why I checked the cam timing off #3 instead). Will continue my mission with the exhaust valves tonight.
there is also some varation from the crank gear not comming around to the same chain link at every rotation when rechecking timing. it takes 9 revolutions to bring everything back to original start of gear and chain link.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Wow, you actually know it takes 9 revolutions
Amazing!!!!I did check the timing twice and they do change ever slightly each time (by ~.01mm). I thought that's operator's error but maybe its just the chain then... At this point, I'm kinda taking the noted & understood attitude. After many moons, I want to drive the car unless its really really bad
It helps to thouroughly oil your chain before starting the process since the chain length will noticibly change depending on if its a little dry or loaded with oil.
Now in 993 land ...
I think this is a good example why any spec comes with a tolerance. What's the tolerance on this? I would not worry about it unless it is far outside the tolerance....
George |
