help replacing MFI bell crank bushing
all;
engine's out for a trans swap. this is one of the "...while i'm in there" chores. now that i'm in there, there doesn't appear to be a way to easily replace the bushings for the MFI bell crank. see pic. any ideas greatly appreciated.
TIA
best
jerry
Old 06-04-2004, 05:41 PM
dtw dtw is offline
GAFB
You'll have to remove either the pump or the throttle. If it were up to me, I'd do the throttle. I don't know another way around this.
Several BMWs
Old 06-04-2004, 09:08 PM
dtw;
thanks... i'm looking for an easyier way around.
p.s. id Geoff ******** a buddy of yours ?
best
jerry
Unclear on the concept ? Let's see if I can help.
1) You are NOT in the "fast lane" and...
2) You are NOT going "fast enough".
**News Flash**
You're in the Passing Lane. Any questions ?
Old 06-05-2004, 10:24 AM
Try not, Do or Do not
Henry Schmidt's Avatar
You can buy a set of bronze bushings and split them into to pieces. You will want to use the thinnest blade you can find for this process. Some hobby bandsaws have such a blade.There is very little load on these bushings and although removing the butterfly housing or pump is the proper way to replace these bushing, the split bushing method will work.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-06-2004, 08:38 AM
DING!
Henry has the answer. the light bulb went on for me yesterday & i thought "...why not" ? i do have a razor saw (Exacto, if anybody's counting) and would strongly suggest anyone else to use one as well. the material removed _may_ be the thickness of a business card. again, no real stress on the parts in question so i feel completely comfortable. thanks all and hopefully this saves someone some time down the road.
cheers
jerry
**News Flash**
Old 06-06-2004, 05:24 PM
