Rear Main Seal Hell
Just rebuilt 2.7, did everything (except case machining). Runs great, had a few small oil leaks I couldn't live with, (valve covers and intermediate plate on front), which I fixed easily when I pulled the engine.
I also had oil leaking out my main rear seal. (Yes I used Curil-T). I replaced the seal, re-installed the engine and it still leaks! ( It drips after one to two minutes of running). I just pulled the engine (I'm getting quick at this). It is not a case leak, it is leaking around the shaft seal. On inspection the seal does not appear to be snug enough on the shaft. I could push a thin strip of paper easily between the seal and the shaft. What could cause this? On inspecting the case the crank is central but the OD of the case is oval by .004". I do not think that is too much for the seal. I don't think the crank is undersized, but I won't be able to mic it until Monday AM. Is there anything that I could have done wrong on assembly to cause oil pressure behind this seal? It also appears that if the seal is pushed too far it can push the shaft seal against crank shoulder, this would definately cause or at least encourage a leak. I may have pushed it in too far. (twice?) I was thinking of slightly shortening the spring in the next seal and aligning the bevel of the seal with the bevel on the case when I push it in. I also plan to fill the engine with oil and tilt it at 45 deg before re-installing as a seal check. (I am afraid I'm wearing out the body mount threads with all the removal and reinstallation ;) ) Are there any shaft kits/sleeves (a la N.A. cars) for worn shafts? Wayne, John Walker, anybody :confused: :confused: :confused: |
Hmm, this is an interesting question. You've replaced the seal twice now, and still have a problem. Did you get the seal from us, or did it come from another source (could be cheapo seal?). How's the surface end of the crank there - any scratches?
You know, I've read this four times, and I can't figure out which seal you're referring to? The pulley seal or the flywheel seal? "main rear seal" means pulley seal (rear of the car). Yet, you mention the crank shoulder, which sounds like the flywheel seal. Please clarify. -Wayne |
Yes, I think I have the proper seal. I bought a bunch of stuff from you Wayne, but not this seal. It is a silicone 65x85x10 orange-ish, it looks just like the one in your book, and the one in your web-site. I can't remember the manufacturers name, but I will get it for you. Original came with my seal kit, second one (same brand) from a reputable P-car parts shop.
I apologize for my V-8 terminology, it is the flywheel seal. I believe the surface looks A1, but I will look again and check the size with a micrometer Monday AM. (I did inspect my crank on tear-down, and I measured the bearing surfaces, but I do not recall measuring the end sizes.) Given the work I've to this engine done it is awful to be stuck on what should be a simple seal.... |
Sounds like there might be something wrong with the machining? .004" is a awful lot. Was the case align bored? It's possible that the the case was improperly bored and was offset from the flange with the flywheel seal. This would only show up with an oil leak and a poorly fitting seal, as the other holes are all drilled together.
"On inspection the seal does not appear to be snug enough on the shaft. I could push a thin strip of paper easily between the seal and the shaft." All the way around the shaft? Or only on one side? It's odd, but your seal sounds too big... -Wayne |
They do make undersized flywheel seals for cranks that have been turned. They are a 1/2mm undersized. What are the dimensions of your crank, and did you use undersized bearings?
The undersized seal is here: http://www.pelicanparts.com/cgi-bin/ksearch/pel_search.cgi?command=DWsearch&description=901102 91100 -Wayne |
When I saw the drips under the car, I was sure that this was a case leak at the joint. I was slightly relieved to see it was the seal. The case was not align bored, and that is now worrying me.
I did a quick check on the crank size with a vernier, then converted on a calculator to mm and I think I was within .001" of spec size, so it does not appear to have been ground. The paper seemed to slip in only at the bottom, but I can't swear to that. I know when I installed the second seal I was surprised at how little friction there was getting the it onto the shaft. It was snug in the case when I tapped it in. I don't feel the .004" should be a problem (he said hopefully), the seal should take that ovality up. Even if the crank were 'running out' relative to the case bore I would still expect it to seal for a short period of time, not to leak with-in the first two minutes of running. Worst case I might have to machine the OD relative to the crank 'in-situ', then sleeve it and re-seal? (I have the facility to do this) I will have someone from 'QC' do a full inspection and I will repost Monday. I think the ball is in my court right now, but the 1/2 mm seal looks like my next option. Something is not right, after years of reading this web-site I haven't seen this before. |
The undersized seal is a half a millimeter larger, so if your crank has been ground, then .001" is a reasonable amount. What is the actual measurement?
-Wayne |
PBH,
I have the same issue on my 2.7. I just don't know what's happening. The first time the seal was pushed out into the flywheel but that was because of an excess pressure build up in the case due to a poorly engineered catch can that didn't vent properly. I used Curil T on the first one and then left it dry on the next install. I thought there would be more friction without the Curil T. I'm exasperated with this because of all the black flags I'm getting at the track for smoking engine! I know this is savage but I'm halfway tempted to JB weld the outside of the seal! Please keep us up to speed on your progress. Tristan |
JB Weld? I'm not quite that desperate. Really close, but not quite. Besides, it won't work. I'm leaking on the crank seal, not on the case seal.
I'm going to post some dimensions Monday AM e.s.t. |
Man this must be contagious! I fired up my rebuilt 2.4T for the first time this Saturday. There are drips coming from the rear of the engine, and so far, all I can see is it might be the flywheel seal. Also, looking at the front, the area behind the pulley appears to be a little wet. I don't see any leaks near the top of the case, and the bottom of the case doesn't leak either. I'm going to pull it to see what's up, but the oil is so clean (now that I changed it), will I be able to tell that it truly is the crankshaft seals, and not the case in that location??
I installed these seals in late December, and wasn't too confident that they were properly seated. I think the Curil-T was hardening from the cold. The front crank pulley seal doesn't have the continuous drips, but the rear flywheel seal does. After further reading, I think this one was pushed in too far. Yes, my seals were all from Pelican. They were part of the Victor Reinz kit. I'll be paying close attention to this thread, I hope resolution is found! |
Jay,
That sounds like the pulley seal not the flywheel seal. It's a much easier fix. Tristan |
I believe they're both leaking. There is a slight wetness at the crank pulley, but alot of dripping coming from the engine to trans connection where the small opening is at on the trans.
I just re-read what I wrote. I always call the flywheel end the "rear". ANyhow, the engine is coming out. |
Jay,
You and I are in the same boat. I have just replaced mine, now I have to do it again. I'm going to Curil-T it this time. Any other brain-waves? Tristan |
This is worse than I thought, only a leak in the case joint could be worse. My ovality is more than I thought. I measured the gap between the crank and the case in four positions, data is below;
12 o'clock - 0.399" 3 o'clock - 0.390" 6 o'clock - 0.394" 9 o'clock - 0.393" The crank measures (by vernier only, no room for micrometer) 2.558", which is 64.97 m, so I think this is standard, not undersized. So, that means my case dimension vertically is 3.351", horizontally it is 3.341, so I'm 0.010" oval. I guess the seal is squeezed oval (side-to-side) and this causes the lip to open top-to-bottom, which is how the oil appeared to be leaking out, ie at the bottom of the crank on the lip. Repair method to salvage a lot of work? I'm planning to put the engine on my boring mill and machine the case round relative to the crank. This should leave me with a bore of .400" all around the crank, that works out to a diameter of 3.358" or 85.3 mm, so I am 0.3 mm oversize and I might need thin sleeve in the case to get the seal tight enough on the O.D. Anybody got any other bright ideas? I don't lack any tools. |
I'm kind of intrigued by the JB Weld idea. You could use it to "fill" the case back to round maybe using one of the old seals as an aplicator and it would machine right out the next time you have it apart. It's half-arsed, but who would know?
You would have to make a sleeve that located on the crank OD (65mm) and was exactly 85mm OD, slap the JBWeld on the the case and push the sleeve in. I guess if the sleeve were nylon it could come out after the JB was dry? My guess is it would crack from thermal stress.
I'm going to try and do this by machining my case tomorrow unless anyone can suggest a better idea or a reason not to... |
PBH,
Very sorry to hear about your predicament. I very much hope that it’s not the same for me. I did use a different crank this time. I guess the problem you have is that much more difficult to solve in that it is leaking on the crankshaft and not the edges of the seal. Can you not shorten the spring as you suggested earlier? |
I found a 0.1 mm tolerance on the Elring web-site for centre-centre alignment. I'm way beyound that as of now.
Hey, at least I have the full machine shop to do it myself without taking the engine apart (again). :) Live and learn with the 2.7. If you do not get your case machined you are asking for just this sort of problem... |
Yes, mine was already line-bored so I'm hoping it was just the outer surface not mating. Let us know how it turns out....sorry couldn't help it :)
Provided no one talks me out of this I will post pictures tomorrow.
Stoddard makes "speedy sleeves" for shafts that have grooves worn in them, odd the the od is that out of tolerance
Tim T:
I think this is a magnesium case issue, from what I've read/surmised this is the result of the case twisting and distorting, over the last 30 years, on an engine that was marginal to begin with. I'm sort of hoping Wayne or someone with case machining expertise will chime in, but I suspect that the bore in this area is usually cleaned up when the cases are sent for align boring. Of course this leads to the question: If this is normally done how do they sleeve it back to 85 mm? :confused: |
This is a problem that should be cleaned up when the case is machined - I'll have to think on it and ask some machinists what they think...
-Wayne |
Here are the do-it-yourself instructions for this repair.
1. Load the engine onto your horizontal boring mill. Be sure to square and level the crank. Dial indicate the crank to find the center. http://forums.pelicanparts.com/uploa...1087319572.jpg Bore out to 86.00 mm, using your precision boring bar. http://forums.pelicanparts.com/uploa...1087319668.jpg Simply press in your sleeve (with loctite), which of course is 85.00 ID with 0.5 mm thick walls. Follow on with your standard seal and Curil-T. http://forums.pelicanparts.com/uploa...1087319792.jpg Note the little notched area where the sleeve nad the red loctite are visible. Cross your fingers and drive off. |
Hopefully that stops the dripping. Let us know how it worked out.
T |
Man, I hope I don't have this problem!
You and me mate. Speaking of which, where is yours? You've been going at it for a while now. What's holding you up?
Tristan |
I've kinda held myself up by not getting orders right in respect of lead in times. I got back my left camshaft last night (wasn't happy with one of the lobes after having their profiles changed from CIS to S). I'm still waiting for a camshaft holder tool to time my engine so I can check piston to valve clearance. I'll then be pulling it all down and rebuilding it with gaskets/sealant. Having the 2.0 still in the car means I've always got wheels, so I'm not rushing anything :rolleyes:
I'm living perpetual paranoia that my engine will leak after reading all these bad news threads.... |
PBH--that has to win the award for the most intense setup of fixing a fully assembled engine I've ever seen...or even thought I'd see. I hope your problem is fixed. That effort truly deserves a leak free engine.
I'll have my engine out tomorrow. We'll see what mine looks like. |
I guess it's proud if it works... |
I think that there's a good chance something will leak. Don't freak out, it's just probable. My engine developed such high oil pressures that it just finds many places to seep out of. I put in the cam oil restrictors which hold the pressure at 20 PSI for every 1k. Places where I had oil leaks of varying amounts: 1. Some of the delicate oil lines feeding the tensioners (didn't want to tighten too much) 2. Oil pressure switch (replaced a couple of times) 3. Crank-case breather hose 4. Thermostat 5. Flywheel seal 6. Intermediate shaft cover I can live with some seepage (normal?) but being black flagged for oil dropping on your heat exchangers from the pressure switch and smoking is not fun. Especially since all you want to do is drive. Oh well, live and learn. Tristan |
When I finished my engine I thought 'this will never leak, if it does, I'll fix it'. Now, a small drop here or there doesn't seem so bad...
I think your perspective changes based on the seriousness of the leaks you've fixed and the time you've spent. At some point you need to get on with your life (and drive your car). See this link (look at the pics), and think about some of the oily Porsche engines you've seen with happy content drivers... http://forums.pelicanparts.com/911-engine-rebuilding-forum/167277-head-leaks.html |
PBH is EXACTLY on the money. That's just how I feel.
Hey, my BMW friends tease me because of my recent dump of oil at a BMW DE. The tech sheet says, “No oil leaks (some seepage is normal)”. Now they always joke about some seepage being "normal". I just smile, they don't understand what it's like to drive this baby on the track. T |
I know what you're saying, but I can't help but remember me mocking English motorcycles and their owners :D Here I am 10 years later being mocked for my oily machine... :rolleyes:
My current engine in the car drops about a quarter sized pool from both sides of the engine each week. Guess I can live with it... |
Fishcop--just take your time with seals, etc. I pulled my engine tonite, and found my problem. I installed my main crankshaft seal (flywheel end) like a moron. When I installed the other case half, the seal was cocked, and it didn't dawn on me just how crooked this seal was.
There's a slight wetness near the pulley end too. I'm going to look into that, and see. if I can seal things up a bit better. But if it's my nose bearing, well...I guess I'll cope. At least this won't drip on any heat exchangers. |
There is an article by Gregory Brown in the Porsche owners club magazine winter 2002. The leaking on the flywheel seal could also be related to using not original main bearings. On the original main bearings the 2 notches are going towards zero depth at the outer end of the flange. This is to reduce oilpressure on the seal.
Andreas |
Anyhow, I think mine is fixed. So far no drippage. Case closed, no pun intended. SmileWavy |
PBH,
Is your motor dry now? Hope so. Tristan |
Hey it's a Porsche. Lets just say that area of the engine is dry now. :)
I had an ongoing unrelated problem with my transmission puking oil out the overflow hole in the top. This would run down the case onto the output shafts and throw oil everywhere. I guess I overfilled the tranny. Anyhow I connected a 1/4" nylon tube from the overflow outlet to the transmission mount crossmember and the last little bits of overflow just drip onto the ground now. Everything else looks (and runs) fine. |
| All times are GMT -8. The time now is 08:43 AM. |
