I need some advice for a 930 !!!!!!!!!!!!!!!!!!
It looks like I have oil leaks between the camshaft housings and the heads. I am thinking on pulling the engine out to correct this problem. The car has about 20,000 Kms. and was stored for 10 years. Is their any other seals, parts or gaskets to be changed now that the engine is out? What other type of work should be done at this time? Thanks for any input....
930 black cabriolet euro 89 |
Slumlord
Done a compression test?
Got 'the book'?
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Id open up the valve covers to see if the source of the leak isnt comming from the rocker arms.
Author of "101 Projects"
Get a copy of the Engine Rebuild Book: http://www.101projects.com - too much info to list here...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
The compresion is OK on all 6 and the leak is not coming from the valve cover. I do have a copy of the Wayne´s engine rebuild book and I plan to use it in my project.
I just wanted some educated guess on what should I change now that the engine will be down to prevent leaks or things going bad in the near future.
Air Medal or two
I do supose you mean oil leak between the head and the rocker boxes??? if so that would not equal a compete tear dwn......to my knowledge there is not a gasket there (unless a 930 is diff from n.a.) I think the big deal is to positivly id it so you do not do a bunch of extra stuff.
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
There is no gasket between the heads and the cam housing, just some loctite sealer. Simon was not refering to the actual valve cover. He was refering to the rocker shaft itself. They can and do leak where they seal into the cam housing. It is a shaft that has a pressure fit. When the bolt that goes through this shaft is tightened upon installation, it expands the ends of the shaft to seal it the camshaft housing. This is a fairly common leak and there are now rubber seals to help solve this problem. If this is where your engine is leaking, It can be repaired with the motor in the car.
Cheers, Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Thanks to Simmon and Jeff and the others for your input. I checked again and I can see a small oil leak coming from the rear side of the camshafts. Their is an o-ring seal and a gasket that I need to replace. After runing the car for 10 minutes I see small drops forming in the joint between the head and the camhousing. Yes I looked it up and it does not use a gasket. It uses 574 loctite.
Do you all think that correcting the camshaft leak by changing the gasket and the seal on the rear side without removing the engine should do the trick?
Robert, are you referring to the o-ring and gasket for the camshaft thrust plate? The one yu get at throught the timing chain box? If that is the one it may help.
If you have a digital camera, snap a pic and post it and let us see the leak. Cheers, Jeff
Is it actually leaking on the ground? Not just a drop a week but a couple of drops a day? If not, you could do a compression check and leakdown to check the engine condition and put the car on jack stands and power wash the bottom of the engine. Then you'll have a good idea where the leak's coming from and you'll be able to drive the car awhile in the meantime.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Yes Jeff, that the o-ring and the gasket.
It leaks a couple of drops after I use the car and I can see some smoke from the oil burning then I start the car and after a few minutes reaches operating temps. Let me try to get a couple of pics tonight and maybe post them tomorrow.
Ok, here are the pics:
this is the patient these are the symptoms
That engine looks brand new compared to what my engine looked like when I pulled it. I would do a compression and maybe leak down test, if they're good I wouldn't worry about it, JMHO.
the drip in the second pic is typically from the thrust plate. the gasket probably got damaged on assembly.
Slumlord
