Oil pressure relief piston - what if stuck?
Just a question:
If an oil pressure relief piston stuck in its chamber while the car was being driven, what would the symptoms be that would indicate that the pressure relief pistons were stuck?
Reason I ask, and I may be way off base here, but one of the reasons I rebuilt my engine initially was because I was getting significant amounts of oil out of the crankcase vent, under hard driving, which I assumed probably meant I had a set of busted piston rings. The rings were fine (pistons were in bad shape though), and now that I've learned more through this rebuild process, I was wondering if it might have been that I had an oil pressure relief piston stuck? Any possibility, or would I see different set of symptoms in that instance?
Thanks,
Brian
Brian Keith Smith
Old 06-15-2004, 12:26 PM
My questions would be, how would a piston get stuck? How much pressure is on that piston at full RPM? I would imagine that it would take a lot to make the piston stuck based on the pressure being exerted on it?
And I'm interested in what the symptons would be? What damage would be done?
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 06-16-2004, 07:08 AM
