BReyes's Avatar
What are shortcomings of having crank Re-Nitrided and polished to get the journal bac
What are shortcomings of having crank Re-Nitrided and polished to get the journal back after spinning rod bearing(it is not that bad but they often are not that bad). $900-1000 is cost to fix crank.
What is the difference if I use such a "repaired" crank on a (i) steeet, (ii) race track.
And has anyone been using Armond at CCR for crank work. He comes highly recommended.Who else does the nitriding well?
Thank You
Bernard
Old 05-04-2005, 09:11 PM
camgrinder's Avatar
The journal will usually have to be welded first, then nitrided. I have seen crankshafts with welded journals used in 911 engines that see 9000+ rpms without any problems.
Armando does excellent work. He can also be very very slow.
John Dougherty
Dougherty Racing Cams
Old 05-05-2005, 02:12 PM
350HP930's Avatar
There is nothing wrong with a reconditioned crank as long as it is done right.
Old 05-05-2005, 05:46 PM
do a search for armando/ccr.
206 637 4071
Old 05-05-2005, 06:50 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
what about nitrating con rods? I have seen rsr rods nitrated, what does this do to the metal and why was it done?
74 911s neverending story. two feet and a jetta for now.
Old 05-05-2005, 07:22 PM
