-   -   964 engine rebuild 11.3:1 compression (http://forums.pelicanparts.com/911-engine-rebuilding-forum/168555-964-engine-rebuild-11-3-1-compression.html)
fstockcarrera 06-20-2004 07:01 AM
I'm beginning a rebuild on a 92 964 race engine. I would like to build to 11.3:1 compression. I appears that we can not get there just fly cutting the heads. We are starting with virgin used heads that will completely be rebuild will competition springs and new Mahle p's&c's.
Question
1. Can we cut the cylinder and if necessary machining the piston domes to get 11.3:1 without compromising the piston dome or ring land strength or integrity.
2. what deck height is reasonable for this application
3. Will the chain tensioners be able to accommodate the
change in height of approximately 1mm
Thanks Bob
ChrisBennet 06-20-2004 07:21 AM
I'm tearing down a '91 964 with a bad piston today. I might be able to slice the piston in half for you if you want to see how thick the piston is in places. I'm curious myself. Let me know.
Why not stretch the rods and address the deck height issues if any?
Did you calculate how much you need to raise the piston to go from stock (10.4:1?) to 11.3?
-Chris
fstockcarrera 06-20-2004 07:31 AM
Hi
It's much easier to cut the jugs.
I would be very interested in the dome thickness.
A have a rough idea that every .0010 gets you approximately .2 in compression.
Bob Scotto [
Wayne 962 06-20-2004 09:28 AM
If you're going for custom compression ratios, and you don't want to worry about a whole mess of other problems (cutting heads, chain lengths, etc.), then I recommend a set of custom pistons from JE...
-Wayne
fstockcarrera 06-20-2004 10:44 AM
Thanks Wayne but in PCA club racing I don't have that luxury.
Will the tensioner handle up to .0040 decrease in height and a ultimate deck height of probably 1.00 mm
Thanks I'm awaiting your book
Bob
ChrisBennet 06-20-2004 11:31 AM
Sorry Bob, the piston looks too mangled to be of use. :(
http://forums.pelicanparts.com/uploa...1087756099.jpg http://forums.pelicanparts.com/uploa...1087756113.jpg
BTW: What PCA class allows a 9 point compression change (10.4 to 11.3:1) but not different pistons?
-Chris
fstockcarrera 06-20-2004 12:54 PM
Yikes! What happen? The Factory spec for the 964 c2 is 11.3:1 even though they are not in reality. Have we met @ LRP. I run the Tag Heuer 964 cup. Bob
ChrisBennet 06-20-2004 01:14 PM
The factory figures are way off. Measure your head and piston volume, calculate the compression ratio and you'll see.
I'm not a racer but I would think that any compression ratio increase large enough to make a difference would also make the motor non-stock.
I might have met you at a DE event in the past. White '86 Carrera. Last year I started wearing blue devil horns on my helmet.
-Chris
fstockcarrera 06-20-2004 01:58 PM
I agree the factory #'s are way off, but
I'm allowed to build to the factory spec. I don't have my #'s in front of me today. Bob
ChrisBennet 06-20-2004 02:47 PM
The factory spec for 964 cylinder heights is 82.750mm (group 5) or 82.770mm (group 6) so if you have group 6 cylinders now you could shave them to group 6 spec and pick up .02mm there. The spec allows refacing the heads by .1mm twice so you pick up .2mm there. That only adds up to a maximum of .22mm. That's going to be far short of your 1mm target - if you want to remain in spec that is. ;)
-Chris
fstockcarrera 06-20-2004 03:14 PM
I 'm assumming a deck height of .0039 or 1.00mm.?? Have not recieved the new P's&C's yet, minus -.20 would give you a deck clearance of .0031 which seems low. The head machinist does not to lower the clearance below .0036 base on a 1mm deck height. I'm using standard rods and new Mahle P's&C's. I really need to measure the deck height. Do you have an idea what it should be??
Thanks Bob
ChrisBennet 06-20-2004 04:39 PM
Thanks Bob
I don't know what it should be. I don't know what the minimum deck height should be. I've been told that you don't want it greater (yes, greater) than 1mm/0.04" because it increases the chance of detonation in the resulting pocket along the outer edge of the piston.
-Chris
Dan J 06-22-2004 07:53 PM
Bob,
You can easily get there by cutting the cyl's. You do need to assemble the lower end first to figure your deck. You also need to have your heads done before you measure your chambers. All the motors are a little different so you have to wait to do the math. Leave yourself a little wiggle room because the "whistler" always reads a little higher then your calculations
Dan J
john_colasante 06-22-2004 08:51 PM
Good stuff Dan. :)
http://www.katechengines.com/img/pro...eropen_std.JPG
KobaltBlau 06-22-2004 11:40 PM
What happen?
Someone set up that motor the bomb!
ChrisBennet 06-23-2004 09:35 AM
What happen?
Sorry, I missed that question. I'm still tearing the motor down so I'm not sure. I suspect the previous owner juxtaposed the piston and valve concepts. :D
All your base are belong to us!
-Chris
john_colasante 06-23-2004 09:39 AM
I'm glad I'm not the only one who still finds that somewhat funny.
KobaltBlau 06-25-2004 11:41 AM
-Chris
exactly! I still think it's funny too... we get signal! http://www.pelicanparts.com/support/smileys/wat2.gif
john_colasante 06-29-2004 07:35 AM
C'mon guys, what are the secrets to getting 11.3:1 in a 3.6? :)
ChrisBennet 06-29-2004 08:48 AM
Different pistons would do it.
I think what is happening is an assumption was made that the factory compression "spec" was just a little high and that a few tweaks could bring it up to "spec".
In reality, the factory compression "spec" is a lot higher than actual (~10.4:1 actual vs 11.3:1 factory).
I think one would need to ignore all the other dimensional specifications to modify cylinders/pistons/etc enough reach the factory compression "spec".
IMO, I don't think any racing body is going to accept a motor with 9 points higher compression (than a truly stock motor) as "stock".
-Chris
john_colasante 06-29-2004 09:28 AM
-Chris
I would think if you built the motor to the spec you are legal.
ChrisBennet 06-29-2004 10:09 AM
Yes, that true but you have to comply with all the specs - not just the compression ratio one.
In this case we are talking about ignoring all the other specs to get a desired compression ratio. There is a spec for the cylinder height for example. You can't just lop off whatever you want.
I don't know if PCA stock rules allow machining of any components short of resurfacing the heads.
I don't know how the factory arrives at their compression ratio (does anyone?) but they are obviously using a different method.
-Chris
john_colasante 06-29-2004 10:44 AM
PCA stock rules say machining for balance purposes only.
Still, I think 11.3:1 MUST be achieved for maximum "stock" performance. Would race gas be required? I guess so.
ChrisBennet 06-29-2004 11:00 AM
Maybe they are already 11.3:1 - using the Porsche compression measuring method.
If there is any question, one could simply ask the PCA Race rules guy. I think we both know what he would say. ;)
-Chris
