964 engine rebuild 11.3:1 compression
I'm beginning a rebuild on a 92 964 race engine. I would like to build to 11.3:1 compression. I appears that we can not get there just fly cutting the heads. We are starting with virgin used heads that will completely be rebuild will competition springs and new Mahle p's&c's.
Question 1. Can we cut the cylinder and if necessary machining the piston domes to get 11.3:1 without compromising the piston dome or ring land strength or integrity. 2. what deck height is reasonable for this application 3. Will the chain tensioners be able to accommodate the change in height of approximately 1mm Thanks Bob |
Irrationally exuberant
I'm tearing down a '91 964 with a bad piston today. I might be able to slice the piston in half for you if you want to see how thick the piston is in places. I'm curious myself. Let me know.
Why not stretch the rods and address the deck height issues if any? Did you calculate how much you need to raise the piston to go from stock (10.4:1?) to 11.3? -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Hi
It's much easier to cut the jugs. I would be very interested in the dome thickness. A have a rough idea that every .0010 gets you approximately .2 in compression. Bob Scotto [ Last edited by fstockcarrera; 06-20-2004 at 08:22 AM.. |
Author of "101 Projects"
If you're going for custom compression ratios, and you don't want to worry about a whole mess of other problems (cutting heads, chain lengths, etc.), then I recommend a set of custom pistons from JE...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Thanks Wayne but in PCA club racing I don't have that luxury.
Will the tensioner handle up to .0040 decrease in height and a ultimate deck height of probably 1.00 mm Thanks I'm awaiting your book Bob |
Sorry Bob, the piston looks too mangled to be of use.
![]() BTW: What PCA class allows a 9 point compression change (10.4 to 11.3:1) but not different pistons? -Chris
Yikes! What happen? The Factory spec for the 964 c2 is 11.3:1 even though they are not in reality. Have we met @ LRP. I run the Tag Heuer 964 cup. Bob
I'm not a racer but I would think that any compression ratio increase large enough to make a difference would also make the motor non-stock. I might have met you at a DE event in the past. White '86 Carrera. Last year I started wearing blue devil horns on my helmet. -Chris
I agree the factory #'s are way off, but
I'm allowed to build to the factory spec. I don't have my #'s in front of me today. Bob |
![]() -Chris
I 'm assumming a deck height of .0039 or 1.00mm.?? Have not recieved the new P's&C's yet, minus -.20 would give you a deck clearance of .0031 which seems low. The head machinist does not to lower the clearance below .0036 base on a 1mm deck height. I'm using standard rods and new Mahle P's&C's. I really need to measure the deck height. Do you have an idea what it should be??
Thanks Bob |
-Chris
Bob,
You can easily get there by cutting the cyl's. You do need to assemble the lower end first to figure your deck. You also need to have your heads done before you measure your chambers. All the motors are a little different so you have to wait to do the math. Leave yourself a little wiggle room because the "whistler" always reads a little higher then your calculations Dan J
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R DanielJacobsLLC.com |
Senior Member
Good stuff Dan.
Andy |
![]() Quote:
-Chris
Senior Member
Andy |
Senior Member
C'mon guys, what are the secrets to getting 11.3:1 in a 3.6?
I think what is happening is an assumption was made that the factory compression "spec" was just a little high and that a few tweaks could bring it up to "spec". In reality, the factory compression "spec" is a lot higher than actual (~10.4:1 actual vs 11.3:1 factory). I think one would need to ignore all the other dimensional specifications to modify cylinders/pistons/etc enough reach the factory compression "spec". IMO, I don't think any racing body is going to accept a motor with 9 points higher compression (than a truly stock motor) as "stock". -Chris
