-   -   3.6 cylinder leakage fix and case mods (http://forums.pelicanparts.com/911-engine-rebuilding-forum/168820-3-6-cylinder-leakage-fix-case-mods.html)
john_colasante 06-21-2004 11:05 PM
What are the modifications necessary to build a leak free 3.6 liter engine, and what are the costs?
What methods can be used to seal both the cylinder/case union and the cylinder/head union?
304065 06-22-2004 11:56 AM
HI JC
Some good info here?
http://forums.pelicanparts.com/showthread.php?s=&threadid=156741&highlight=peter+ dawe
john_colasante 06-22-2004 04:02 PM
It's all there, thanks JC!
Bill Verburg 06-22-2004 04:04 PM
JC, is this for your Cup car? Ingo had his stock cylinders machined by Walt at CE. The cylinder base gaskets were updated for the 109mm 993RS spiggots, as far as I know the stock 964 o-rings are adequate most of the time. Some builders put a dollop of something like Dow Corning 730 anaerobic sealant for extra insurance.
I see that you are in the market for a replacement aluminum hood as well?
john_colasante 06-22-2004 04:12 PM
Yes Bill, I need to start planning for a rebuild. My cylinders are leaking more and more lately.
Also, take a look at this thread. Can you lend some insight there?
http://forums.pelicanparts.com/911-engine-rebuilding-forum/168555-964-engine-rebuild-11-3-1-compression.html
Bill Verburg 06-22-2004 07:17 PM
I'll bet OZ knows;)
and I'll bet Bob will find out.
I don't really know as I only ran into the base issue and wasn't as concerned w/ taking the rest of the specs to the limit.
PCA wouldn't allow JEs made to the 964 11.3 spec and dome shape?
Here's a pic of the bottom of your engine that I took at the Glen
http://forums.pelicanparts.com/uploa...1087956903.jpg
Doesn't look that bad
