Anyone need an intake manifold?
I have from an early 964, the intake manifold, it the aluminum style, not the plastic runners. Anyone need it????
Old 08-26-2004, 04:49 PM
Jeff Alton's Avatar
Maybe..... could you fab up some adapters to fit it on a 3.2??
Jeff
www.turn3autosport.com
Old 08-26-2004, 08:27 PM
Zombie
Yes, you can send it to me.....
Just bought 3.2 manifolds for my 3.0. Early 964 manifold would have been nice.
Timo
914-6
Old 08-26-2004, 11:51 PM
Irrationally exuberant
ChrisBennet's Avatar
Jeff
Jeff,
I looked into this some and I thought I'd share what I discovered:
* Unlike the 3.2 manifolds, the 3.6 manifolds have a seperate injector block that bolts to the head. A rubber sleeve connects each the injector block to the manifold.
* I bought a plastic intake manifold a while back and the didn't come with the part (injector block) that bolts to the heads. Technically I guess it isn't part of the manifold.
* The 964 parts that bolt to the heads have a different bolt pattern than the 3.2. The 964 has 3 6mm studs vs the 3.2's 2 8mm studs. A couple of places make adapters (for around $300 a set) that convert from 3.6 ot 3.2.
* If I use the 3.6 manifold on my 3.4 I think I'll have injector blocks with the 3.2 bolt spacing made up. Paging Mr Garibaldi...
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 08-27-2004, 05:51 AM
wot wot is offline
wot's Avatar
Hi
here you can bye the adapters. expensive?
http://www.stigsgarage.se/delar.htm
Erik
82 SC 3,6 73 RS Look
Old 08-30-2004, 03:26 AM
Very nice! I wonder what 600 Euros is in American $.
I wonder it there would be a market for these if you had some castings made.
-Chris
Old 08-30-2004, 11:07 AM
KobaltBlau's Avatar
according to xe.net $723. youch.
But here's a (possibly stupid) idea: If your 3.2 based engine still has 40mm intake ports, why wouldn't you cut off the ends of your 3.2 manifold and connect them with the rubber tubes to the 964 manifold?
Andy
Old 08-30-2004, 01:01 PM
BURN-BROS's Avatar
Andy, I think you could sell the 3.2 intake and the proceedes could go to the intakes. Yikes on the price though, castings should be way cheaper if one were to make them.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 08-30-2004, 01:18 PM
Jeff Alton's Avatar
Chris, thanks for your input. I too was thinking for a future 3.4 upgrade.
What about Andy's idea?? Seems like it might work.
Jeff
Old 09-03-2004, 10:43 AM
Jeff
Andy's idea would work I think. It would have a smaller inside diameter than the 964 intake. I think the 3.2 intake would sell for a couple of hundred $ without injection so one would have to weigh just selling it against modifying it.
-Chris
Old 09-03-2004, 08:31 PM
Jeff Alton's Avatar
Hmmm, good point about the price. This is going to require more thinking.
Jeff
Old 09-04-2004, 09:11 AM
