-   -   Removing sealant between the case halves (http://forums.pelicanparts.com/911-engine-rebuilding-forum/173314-removing-sealant-between-case-halves.html)
Torsc 07-20-2004 07:26 AM
I am rebuilding my 3,2 engine. I have dismantled the whole engine and cleaned all part except the mathing faces between the case halves. Does anyone have a tip how to removed the old sealant without damaging the mathingfaces?
ChrisBennet 07-20-2004 03:44 PM
Permatex Gasket Remover works great. Be careful not to get any on your engine stand of it will take off the paint. I use a one sided razor blade after that and scrape in the direction of the seam so if I make a nick it won't make a groove leading from in to outside the case. I pre bend the razor blade slightly so when I press down it flattens out - it doesn't tend to catch the edges that way.
-Chris
Rondinone 07-20-2004 04:49 PM
I used 100% acetone and scotch brite pads.
Torsc 07-21-2004 07:34 AM
Thanks for you advices. I bought CRC gasket remover today. Will try it later today.
