Cut Fuel Injection Hose
Just kidding about the exray vision, but if anyone spots some obvious misstakes, I'd appreciate the feedback.
The hose on the fuel injection was cracked, so I cut the end off. Looks like the end is wider to go over the fitting. Does anyone know for sure?
Old 07-24-2004, 04:23 PM
Try not, Do or Do not
Henry Schmidt's Avatar
The hose is pressed on with a special tool.
Hard polymid line is installed using a tool that clamps the line 1/2 inch from the end and then you apply pressure until hose is installed flush with the end.
Without the tool you're swimming up stream. You might get it but you'll throw tools and make yourself crazy first.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-24-2004, 07:00 PM
