iamchappy's Avatar
turbo scavenge oil pump
Does anyone know were I can source a new or used 930 turbo oil scavange pump.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 07-27-2004, 04:26 PM
Try not, Do or Do not
Henry Schmidt's Avatar
We have this and many othet Porsche engine parts in stock.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-27-2004, 08:03 PM
magic930's Avatar
Henry is it difficult to replace the small red seal in these scavenge pumps?
iamchappy apologies for the post hijack!
Old 07-27-2004, 09:02 PM
It's child's play. Simply push out the drive pin and remove the two bolts that hold the pump together. Next you tap on the pump shaft and cover and drive gears will come out.
Access to the seal at that point is easy. There is also an oring inside (the pump) that should be replaced at this time.
Good luck
Henry Schmidt
Ph: 760-728-3062
Old 07-28-2004, 08:24 AM
iamchappy's Avatar
Henry,
Thank you for taking the time during your busy day this morning to talk to me about my turbo oil problem . I will probe further and try to resolve some of the problems you have suggested I try and see if that helps things, if not, I know you have a pump for me that I am confident would scavenge the oil.
Chap
87 924S
Lexus SC400
Lexus LS400
Old 07-28-2004, 05:39 PM
