OK so I have the engine and tranny out to redo the clutch while it is out I decided to adjust the valves, this is the first time. I had already turned the engine back wards about a turn trying to get it to tdc when i read the next step in the directions that says only turn it clockwise. I'm hoping i didn't screw anything up. what gets damaged if the engine is rotated counterclockwise?
Slumlord
I believe the problem is the chain tensioner doesn't work when you run in reversed, so you lose valve timing. If you didn't force it the engine should be fine. I think.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
a non-problem.
Slumlord
Since you have only 5 posts: Whatever John Walker says is correct.
3 restos WIP = psycho
Yep. John Walker answering a question is like God speaking. You can take it on faith alone.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
...and the clouds parted and the angels sang and God hath spoken...
_______________ Glenn from Denver 94 964 3.8 RSR |
thanks!!!
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
MBruns for President
waaaaaaaaaaaaaa <--------angels singing........
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
oh jeezus!
Slumlord
No! Oh God....
...you devil.
In case your vehicle is a 912
it's easier to adjust valves counter clockwise, in that way you start at no.1 then 4, 3 and finally 2. you don't have to swap from side to side. Neat hey! but you don't have a 912 do you?
