nreed's Avatar
crankcase vent question
How long would it take to damage rings and flywheel seal if the crankcase vent was accidently plugged?
Norm '86 930
AEM Infinity 6 - Twin Plug 3.6L - DBW - JE Pistons/LN Eng. Cylinders - Pauter rods - GT3 Crank - GTX3584RS - ID1050x Injectors - Ported Intakes - Custom Intake Manifold, exhaust and intercooler - 993SS cams - ECUMASTER PMU-16DL
HRE Wheels 560R 8.5x18 ET25 (Front) 11x18 ET0 (Rear)
Old 08-23-2004, 01:27 PM
Not sure you would experience piston ring damage.
Oil will find it's way out of the crankcase via the weakest gasketed/sealed joint. Could be a crank seal but also through a hose connection or a valve cover gasket.
If you inadvertantly and temporarily plugged the crankcase vent and you haven't experienced any leaks, you're probably safe.
MHO,
Sherwood
Old 08-23-2004, 03:46 PM
You woudl probably push some seals out, whichever is easiest for the blowby to move first.
Old 08-23-2004, 07:05 PM
