Motor Meister
Anyone use them. I am looking for a rebuild on my 87 911. Usual 100k starting to smoke quite abit. At start up and after idle. Any tips? Other places?
Thanks in advance. |
Use the seach button in the upper right corner and search for MM. There are some interesting opinions.
Lots a great builders in the CA area. |
Do a search, plenty of posts about motor meister, almost all of them negative.
I have never used them myself because of all the alleged horrible things I've heard about their work and ethics. |
go see TRE in north hollywood. sounds like the valve guides are worn out, which is typical of 100K carreras. a simple valve grind is probably all you need.
| All times are GMT -8. The time now is 08:56 AM. |
