strep's Avatar
Motor Meister
Anyone use them. I am looking for a rebuild on my 87 911. Usual 100k starting to smoke quite abit. At start up and after idle. Any tips? Other places?
Thanks in advance.
Old 09-05-2004, 04:17 PM
I would rather be driving
jpnovak's Avatar
Use the seach button in the upper right corner and search for MM. There are some interesting opinions.
Lots a great builders in the CA area.
Old 09-05-2004, 04:33 PM
Unregistered
sammyg2's Avatar
Do a search, plenty of posts about motor meister, almost all of them negative.
I have never used them myself because of all the alleged horrible things I've heard about their work and ethics.
go see TRE in north hollywood. sounds like the valve guides are worn out, which is typical of 100K carreras. a simple valve grind is probably all you need.
206 637 4071
Old 09-05-2004, 05:23 PM
