Has anyone ever ran their engine without the chain covers in place? The reason I ask, I removed the covers to inspect the tensioners, I can not see where the chain might be hitting the case. The chain noise is on the right side, is there a certain place where the right chain usually hits the case when a tensioner goes bad? How big of a mess will it make running it long enough to see what is going on there, maybe a minute or so? I was going to connect the oil feed lines back to the tensioners then put cardboard on the floor and have the oil dry handy. The chain rails appear to be ok. At idle it is not really noisey, but if you increase the engine speed, it gets the chain dragging noise in the right side.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
Yes, you can run it with the covers off, its makes a little bit of a mess, but its not bad
MAGA
FWIW, When I pulled mine down (79 SC w/ hyd tensioners), I found the right tensioner was froze on the shaft and the pressure relief ball spring and retainer cap were laying loose in the bottom of the chain case!
I doubt yours would be frozen, but it would not hurt to look at the pressure ball and spring that is located just off the side of the plunger on the tensioner.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Check if the rignt side camshaft sprocket are installed in the wrong way and if the chain are touching the housing behind the chain itself.
1972 911T 1991 Mazda RX-7 Turbo II Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life! |
Take some good pictures and post them to the thread. Perhaps someone can spot a potential problem without you having to go thru all the hassel.
As they say "A picture is worth a thousand words". |
