Alan Cottrill's Avatar
I'm glad this worked out!
now...are you sure you put the seals on the oil pump?
sorry couldn't resist. I forgot to put them in the first time I assembled my case. I remembered the second time I assembled my case, but that time I pulled one of the perimiter studs. the third time I assembled my case I got it all right.
big AL
'77 911
Old 09-22-2004, 01:43 PM
Friend of Warren
Put plastic wrap over the openings in the piston case to keep the wrist pin clips from flying off and dropping down into the engine!!!!!
Kurt V
Old 09-22-2004, 02:56 PM
cassidyp's Avatar
Didn't get as far as I would have liked. Something about having 3 young kids... I did put the rings on 3 of the pistons and that wan't too bad. I found that the tool I purchased was sort of clumsy so I just used my hands. I have Wayne's book and can see why the plastic wrap is so important.
I did read that I should start at the transmission side and work backwards when installing the pistons on the arms. Also install one circlip while on the workbench right?
72 911 Targa VTK Member 110245
71 911 Targa
68 911 non sunroof Coupe
Gruppe B # 3911
http://www.pelicanparts.com/gallery/cassidyp
Old 09-23-2004, 04:53 AM
Friend of Warren
Yes one circlip on the bench and the other after the piston is installed.
Kurt V
Old 09-23-2004, 08:44 AM
