Eli K's Avatar
How many plugs for air pump removal?
Getting ready to remove the smog pump on my '78 SC. Before I get started could someone tell me how many plugs I need to get for the head? Searched for the last 20 minutes but couldn't find any posts refering to the amount. Don't want to tare the car apart just to find out I'm short on plugs
Eli
Just noticed I'm in the wrong forum..couldn't delete the post
Old 11-06-2004, 06:12 PM
tops911's Avatar
You'll need 6 plugs one for each injector. If you have an EGR and are removing it as well you would need an oil tank drain plug (thanks John Walker) to plug the hole in the air box. This is what I did on my 78 SC, but started life as a California car, I dont think all have EGRs.
good luck
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel
Old 11-07-2004, 06:23 AM
