nreed's Avatar
I seated mine up against the case as far as it would go with a lot of curil-T. But because there was a moment in time where my crankcase was not vented properly I have wondered if it was pushed out slightly or damaged.
That area is also a bit tricky with the case sealant. I was worried that I would get some of the case sealant on the front bearings so I may have missed a spot. It may not be the seal at all.
Norm '86 930
AEM Infinity 6 - Twin Plug 3.6L - DBW - JE Pistons/LN Eng. Cylinders - Pauter rods - GT3 Crank - GTX3584RS - ID1050x Injectors - Ported Intakes - Custom Intake Manifold, exhaust and intercooler - 993SS cams - ECUMASTER PMU-16DL
HRE Wheels 560R 8.5x18 ET25 (Front) 11x18 ET0 (Rear)
Old 10-20-2004, 07:39 AM
nreed's Avatar
Dave,
I forgot to mention that I would like to help you work through the cam sensor issue if you want. If you can get your hands on any low frequency oscilloscope that will help.
Norm '86 930
Old 10-20-2004, 09:35 AM
magic930's Avatar
Thanks Norm, I will be double checking the injector wiring and cam sensor wiring when I get the engine out.
Old 10-20-2004, 10:06 AM
