-   -   Oh, Heck (http://forums.pelicanparts.com/911-engine-rebuilding-forum/184354-oh-heck.html)
jakev 09-25-2004 03:14 PM
Oh, Heck
I am removing the SSI heat exchangers from my engine. I am using a long 8mm allen socket with a T-bar. 4 out of 5 came out OK. #5 is slipping. Somebody else used the wrong size allen socket. (5/16?) So, is there a long EZ-out that you use? Go to a 9 mm allen socket?
NevenM 09-25-2004 03:49 PM
Hi
Check that the allen socket is seating right in, I had a case where the exhaust stud has been left too long, which means you tighten the barrel nut and eventually the sockets slips.
My solution was to use a dremel to hollow the end of the allen socket so that it fitted over the head of the stub (this gave about 2mm more grip area)
HTH
Neven
magic930 09-25-2004 06:06 PM
Try 2 things, spray with a penetrant and leave it overnight. If that doesn't work then heat it up with a torch. If all else fails you can jam a 12 point into it. (but I admit that might be bad advice!)
audi2.7t 09-26-2004 07:57 AM
Hammer a Torx driver into it then use heat around the base of the bolt....
Jubbie 09-26-2004 03:25 PM
I used the craftsman bolt out. See this post
http://forums.pelicanparts.com/porsche-911-technical-forum/176059-exhaust-manifold-nut-salvation.html
It worked great.
jakev 10-02-2004 11:10 AM
I followed NevenM's advise, and hollowed out the end of my 8 mm allen socket. It still slipped. I then drilled out the top of the stud. I used the allen socket, and it still slipped. The end of the socket was thin, so I gave it some love taps to crush it a bit. I then used the socket, and voila, the barrel nut broke free. So, problem solved. Thanks to everybody for their advise.
Jeff Alton 10-02-2004 11:44 AM
Jakev, where abouts are you in BC?
Jeff
jakev 10-02-2004 12:28 PM
Prince Rupert
