Angry Oh, Heck
I am removing the SSI heat exchangers from my engine. I am using a long 8mm allen socket with a T-bar. 4 out of 5 came out OK. #5 is slipping. Somebody else used the wrong size allen socket. (5/16?) So, is there a long EZ-out that you use? Go to a 9 mm allen socket?
71 911T/2.7
Old 09-25-2004, 03:14 PM
Hi
Check that the allen socket is seating right in, I had a case where the exhaust stud has been left too long, which means you tighten the barrel nut and eventually the sockets slips.
My solution was to use a dremel to hollow the end of the allen socket so that it fitted over the head of the stub (this gave about 2mm more grip area)
HTH
Neven
Old 09-25-2004, 03:49 PM
magic930's Avatar
Try 2 things, spray with a penetrant and leave it overnight. If that doesn't work then heat it up with a torch. If all else fails you can jam a 12 point into it. (but I admit that might be bad advice!)
Old 09-25-2004, 06:06 PM
audi2.7t's Avatar
Hammer a Torx driver into it then use heat around the base of the bolt....
'96 Dodge Viper
'09 Maxima
'05 zx10..(0-100-0 before your turbo even spools!!)
'99 Rottweiler
'08 Cane Corso
Old 09-26-2004, 07:57 AM
Jubbie's Avatar
I used the craftsman bolt out. See this post
Exhaust Manifold nut salvation
It worked great.
John F. Lewis
74' 911S Targa + 930/02
76' 914 - Eternal Type IV project FOR SALE
Old 09-26-2004, 03:25 PM
I followed NevenM's advise, and hollowed out the end of my 8 mm allen socket. It still slipped. I then drilled out the top of the stud. I used the allen socket, and it still slipped. The end of the socket was thin, so I gave it some love taps to crush it a bit. I then used the socket, and voila, the barrel nut broke free. So, problem solved. Thanks to everybody for their advise.
71 911T/2.7
Old 10-02-2004, 11:10 AM
Jeff Alton's Avatar
Jakev, where abouts are you in BC?
Jeff
www.turn3autosport.com
Old 10-02-2004, 11:44 AM
Prince Rupert
71 911T/2.7
Old 10-02-2004, 12:28 PM
