Speed Junkie
What are these doin in here??
Hey, I have a 89 930 with engine code 930/68. When I got to the pistons, I noticed that they are flat top Mahle pistons. Is this right?? Everything I've read and seen up to this point has had half dome shaped pistons. This concerns me since I have always thought the half domed piston design was inherent for proper combustion of the CIS fuel systems. Can anyone possibly help clear this up for me?
Thanks,
I would rather be driving
I think the domed shape is only for NA engines. your turbo has lower compression and its not surprising to me to see flat top pistons.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
stock 930. notice the exhaust valve contact notch.
Brian Keith Smith |
Low compression turbo pistons will be flat or less than flat.
Sherwood |
Speed Junkie
I can't remember (forgive me, but I've been browsing the Porsche forums like a mad man for the past few weeks). Did you go to EFI on your build? |
Yes, I went EFI. 431.8HP to the rear wheels and I am told there is more there with some more tuning on the computer.
Brian
Brian Keith Smith |
