Speed Junkie
What are these doin in here??
Hey, I have a 89 930 with engine code 930/68. When I got to the pistons, I noticed that they are flat top Mahle pistons. Is this right?? Everything I've read and seen up to this point has had half dome shaped pistons. This concerns me since I have always thought the half domed piston design was inherent for proper combustion of the CIS fuel systems. Can anyone possibly help clear this up for me?
Thanks,
Old 09-26-2004, 07:07 AM
I would rather be driving
jpnovak's Avatar
I think the domed shape is only for NA engines. your turbo has lower compression and its not surprising to me to see flat top pistons.
Old 09-26-2004, 08:12 AM
stock 930. notice the exhaust valve contact notch.
206 637 4071
Old 09-26-2004, 09:13 AM
Check out my rebuild pics, yes you have the right pistons in there.
Brian
Engine Rebuild Pics
Brian Keith Smith
Old 09-27-2004, 12:04 PM
Low compression turbo pistons will be flat or less than flat.
Sherwood
Old 09-27-2004, 06:07 PM
Speed Junkie
Brian
Engine Rebuild Pics
Brian,
I can't remember (forgive me, but I've been browsing the Porsche forums like a mad man for the past few weeks). Did you go to EFI on your build?
Old 09-27-2004, 08:14 PM
Yes, I went EFI. 431.8HP to the rear wheels and I am told there is more there with some more tuning on the computer.
Brian
Brian Keith Smith
Old 09-28-2004, 08:16 AM
