-   -   Supertec is building us a turbo motor! (http://forums.pelicanparts.com/911-engine-rebuilding-forum/184946-supertec-building-us-turbo-motor.html)
Lensart 09-29-2004 01:44 PM
We just ordered a 3.4L turbo engine from Henry to go in a race car we will be building this winter. Maybe he will chime in here and give us updates and pic's of the project. Henry is a great guy to talk to and we picked him over 5 other engine rebuilders from all over the country. We are shooting for 400-450 reliable h.p.
Specs:
Supertec 930 Hi Performance street engine.
Extras:
Port Heads 38mm in 38 mm ex
Port Intake Manifold 38mm
Supertec Head Studs
High Performance Cams (not sure yet what to use)
3.4l Pistons and Cylinders 7.5 to 1
C2 Intercooler
GHL headers
Turbo (I need help on this one, K27HF or K27 7200 or K29 or???).
Any advice on the Turbo and Cams selection would be helpfull.
Thanks, Randy
KobaltBlau 09-29-2004 03:28 PM
I think you made a very good choice ;)
briankeithsmith 09-29-2004 06:40 PM
Randy:
If you go with the K27HF, you will most likely run into overboost with the GHLs unless you modify them. The K27HF flows alot of air, and the GHL wastegate circuit is 40mm, which isn't quite big enough.
Check out turbo911.com for similar reports of this.
I built my engine recently and converted to EFI in the process. I ended up with 431.8RWHP and I think it will be very reliable.
Pics are at:
http://www.competitioncustompaint.com/rebuild/rebuild.html
I installed GHL's and the K27HF and I can easily see 1.4bar of boost through my Tial wastegate with a .8bar spring. So I can't flat foot my car at all until I get this addressed.
Brian
Lensart 09-29-2004 07:20 PM
Thanks Brian, great job on your engine! Your advice is to pick a smaller tubo if I use GHL headers? What do you plan to do? I expect my engine to be on boost almost all the time as it's in a race car only.
briankeithsmith 09-30-2004 05:19 AM
No I'm not saying that. I like the K27HF, and my car is a 90% track car only. I rarely drive it on the street.
I'm just saying that before you bolt on those GHL's you are going to have to modify them more than likely so that you can flow more air through the wastegate circuit of the headers. The wastegates themselves seem to be big enough, or at least that is what most people agree on, but the GHL 40mm pipe isn't big enough. And the fact that they circuit is perpendicular to the air flow going to the turbo doesn't help much.
My plan is to modify the headers, which REALLY PISSES ME OFF. I hate the fact that I have to cut a brand new set of headers. But I was told that it would all work together, and it doesn't. So that's why I'm telling you that potentially you could run into the same thing. It looks like you are staying CIS, so you may not have as big of an issue. You may be able to run .8bar and end up with just over 1 bar. But 1.4 in my case is just too much.
Brian
beepbeep 09-30-2004 06:43 AM
I beg to differ. First of all, there is nothing that says that you just have to use KKK turbochergers when building turbocharged Porsche engine. Yes, Porsche used them for a while (first turbos used Eberspächer turbochargers) but nowadays there are very good performance-turbochargers available and KKK seem to have fallen back when it comes to development of bigger turbochargers. There are very few compressor maps available to begin with...so many engines are built by using turbochargers modified according to mumbo-jumbo black magic w/o really knowing the exact characteristics of those pieces. Those (few) K27 maps I saw weren't too impressive.
I suggest looking towards Garrett's range of turbochargers. They are good, they are (relativly) cheap, they can be ordered with BB-assemblies and best of all, [b]there are reliable and comprehensive compressor and turbine-maps[/] available.
A GT40R-BB (or maybe GT35 version, if you need less headroom but more response) will cover all your needs and leave room to grow in.
Second:
The less backpressure the turbocharger represents (=the bigger the turbine, and thus the turbine flow), the smaller wastegate you need.
Exhaust gases going trough wastegate are surpluss that isn't allowed to go trough turbine, remember? So if your turbine is very small you'll need big wastegate that will route majority of those gases around.
Wastegates with diameter of 40mm and higher are quite enough most of the times, especially with bigger turbochargers. Attention must be instead payed to mating of wastegate-pipe and header collector. Exhaust gases that are required to make sharp turn to be able to flow trough wastegate will flow badly, leading to overboost-problems.
Regards,
Lensart 09-30-2004 07:41 AM
"It looks like you are staying CIS, so you may not have as big of an issue. You may be able to run .8bar and end up with just over 1 bar."
Yes we're going with CIS for now, and I was told be Kevin (turbo guru?) that GHL is a good header to use and he recomended K27. He said start at .7 spring.
"I suggest looking towards Garrett's range of turbochargers. They are good, they are (relativly) cheap, they can be ordered with BB-assemblies and best of all, [b]there are reliable and comprehensive compressor and turbine-maps[/] available."
Henry is looking into Garrett's for me now, you seem to know a lot about turbo's I have been reading a lot of your posts. I want to choose a turbo and cam's that will work best for our engine and track. We'll run mostly on a track (1.8 miles) with 11 curves, mostly short straights (a lot of drag races to the curves). The car should be around 2000- 2200 lb.s Does any of this info matter in the selection of cam's and turbos?
Thanks for your help!
Randy
briankeithsmith 09-30-2004 07:46 AM
beepbeep: Your point is the point I was trying to make. The GHL Collector has the wastegate circuit at a 90 degree angle to the air flow. My wastegate is a 46mm, but the pipe coming from the GHL to the wastegate is a 40mm, so there is a mismatch there.
Brian
1fastredsc 09-30-2004 10:18 AM
Originally posted by beepbeep
[B]I beg to differ. First of all, there is nothing that says that you just have to use KKK turbochergers when building turbocharged Porsche engine. Yes, Porsche used them for a while (first turbos used Eberspächer turbochargers) but nowadays there are very good performance-turbochargers available and KKK seem to have fallen back when it comes to development of bigger turbochargers. There are very few compressor maps available to begin with...so many engines are built by using turbochargers modified according to mumbo-jumbo black magic w/o really knowing the exact characteristics of those pieces. Those (few) K27 maps I saw weren't too impressive.
I suggest looking towards Garrett's range of turbochargers. They are good, they are (relativly) cheap, they can be ordered with BB-assemblies and best of all, there are reliable and comprehensive compressor and turbine-maps[/] available.
Second:
Regards,
That's a very good point made by beep. Even if you can't swing the cash for the GT series turbos, a regular garret is still better than the old fasion KKK, plus there are a ton more compressor/turbine configurations to suite the very specific needs of your particular engine. With the KKK, you'll never get it at it's peak efficiency for you individual needs. They are great bolt on upgrades for stock 930 motors, but if you building a motor and have the option of starting fresh with new headers, any turbo of your choice, and so on, then i'd go with the garret as well.
Lensart 09-30-2004 11:36 AM
I'm new to the turbo world. If we are to pick a Garrett where do we start? What engine and or car specs do we need to take into account? I'd like to stay under $1500. Any advice?
Randy
briankeithsmith 09-30-2004 11:42 AM
The other thing to keep in mind is that if you go with a Garrett, you may need to go with an aftermarket scavenge pump to replace the current stock scavenge pump.
Some people have had flow problems with the stock scavenge pump and Garrett turbos.
Brian
beepbeep 09-30-2004 12:00 PM
Brian
Hmm...as far as I know, Garrett's actually require less oil flow than KKK's so it shouldn't be a problem, especially if you equip the oil-feed with reducer-valve.
Granted, two GT30's will be a problem (i have a friend who's 930 scavenge pump couldn't evacuate enough from his GT30 twins)...but one shouldn't make any trouble.
beepbeep 09-30-2004 12:13 PM
Randy: first step is to decide which rev- and boost range you will be using the most. You can then calculate mass flow of air (lbs/min) for that particular range and plot it into compressor maps of few different sizes of turbochargers you have your eyes on.
Goal is to keep the dot into it's most efficient range as much as possible troughout your "track pass".
So if you are going to drive from 4000 to 7000 RPM using 1 bar of boost, it's going to "eat" certain amount of air per minute (38 lbs/min @ 7000 RPM and 1 bar of boost to be exact).
Download the catalog of Garret turbochargers and check out which suits you the most. W/o really looking into it, I believe GT30R and GT35 will suit your need the best.
PM your mail adress and I'll mail you catalogs if you cannot find them online.
Regards
1fastredsc 09-30-2004 04:55 PM
www.turbonetics.com
They list some of the older garret housings and there efficiencies. Beep probably has a wealth of info on the GT series.
Lensart 10-01-2004 12:33 PM
I have some studying to do! I found the Garrett catalog and bought a turbo book. Hopefully I can learn how to use all the charts. I'm going to the races this weekend so it may be a coulpe days berfore I can get on this.
Goran, will the Garretts bolt on the GHL headers or will I have to change the flange? Will they work with the stock oiling system?
Thanks to all, Randy
beepbeep 10-01-2004 01:37 PM
'bout the wastegates:
http://forums.pelicanparts.com/uploa...1096662208.gif
http://forums.pelicanparts.com/uploa...1096662344.gif
Randy: I don't know how GHL headers look like. Bigger non-R Garrett's have something called "twin scroll" turbine housing, so flange looks like this:
http://project911.luminasweden.com/log_images/168_6898.jpg
R-models (Race models equipped with ball bearings) have single port intakes, so it all depends on which turbocharger you opt for.
Turbo will work off the stock oiling system...at least as long as you have only one.
Talking about books, I bet you bought Bell's "Maximum Boost"? It's a good book ;)
beepbeep 10-02-2004 06:25 AM
Here's example of well-done 911 turbo headers I found somewhere on internet. They should be wrapped with thermal blanket for best efficiency. Match these with GT35R, twin-plug, speed/density EFI and good intercooler and you are good for some big horsepower.
http://forums.pelicanparts.com/uploa...1096723402.jpg
http://forums.pelicanparts.com/uploa...1096723415.jpg
beepbeep 10-02-2004 06:27 AM
Here are maps for GT30R and GT35R with surge-lines and max boost (1.7 bar) drawn in red:
http://forums.pelicanparts.com/uploa...1096723813.jpg
http://forums.pelicanparts.com/uploa...1096723623.jpg
mwildt 10-02-2004 07:24 PM
Hi BeepBeep,
A friend of mine is into tractor pulling (in Denmark) and is playing with diesel turbos. Can you recommend other books that 'Maximum Boost' ?
Thanks,
Michael
beepbeep 10-03-2004 08:30 AM
Originally posted by mwildt
Hi BeepBeep,
Thanks,
Michael
Best:
Forced Induction Performance Tuning A Practical Guide to Supercharging and Turbocharging by A. Graham Bell
Maximum Boost by Corky Bell
Also good:
Supercharging, Turbocharging, & Nitrous Oxide Performance Handbook (Powerpro) by Earl Davis, Diane Davis
Turbochargers by Hugh MacInnes
Diesel turbochargers are cheap and often used on gasoline cars. Unfortunately, they are built to withstand millions of miles and are often 50% heavier than it's gasoline counterparts. They are also customized out of factory to fit their specific application, which means that they might not be optimal for your application (turbine/compressor ratio is often skewed towards bigger turbines). Ported-shroud holes are often missing too. On the flip side, they seldom have bearing problems and are cheap and dependable.
mwildt 10-03-2004 08:42 AM
Thanks for the book list. Much appreciated.
The engine they are working on is a V10 Diesel wich gives ~2000HP at 4000 rpm. The boost pressure is 10.5 Bar, reduced from 12.0 Bar. Some serious stuff. http://www.teamdingo.dk Unfortunately the web page is in Danish, but I doubt that will give you much trouble ;-)
Thanks,
Michael
1fastredsc 10-03-2004 10:21 AM
Hey beep, where did you find those headers, they are gorgeous? I've never seen them before either.
DonE 10-03-2004 07:07 PM
Those headers were made by Marco Manzie in Ft Lauderdale. The are 1 3/4 primaries for custom 3.55L 930.
Lensart 10-05-2004 01:55 PM
Goran, I went through a ton of math (not my strong point) and came up with:
35.8 lb.min @ 7000. 31.01 lb.min @ 6000. 26.73 lb.min @ 5000. 20.85 lb.min @ 4000. 16.04 lb.min @ 3000. at 1.bar and presure ratio 2.01 with a 80% volumetric efficiency. I used some charts to get some of the info (I'm lazy) so the numbers may not be exact. Do you think I'm close?
How important is the 3000 rpm point as it's pretty close to the surge line.
I'm looking at Gt30R and Gt35R maps but I'm not sure where the points should end up.
Thanks Randy
Lensart 10-05-2004 02:25 PM
Pics of headers and intercooler:http://forums.pelicanparts.com/uploa...1097011532.jpg
DonE 10-05-2004 05:02 PM
You have a KKK flange on your headers, so in case you plan on replacing it, a Garrett will not fit. For the motor you are building, the HP you want to make and you seem to be staying with CIS, the K27 7200HF is probably your best choice. Your biggest concern should be how you are going to feed that 3.4L motor enough fuel to maintain 12.2:1 AFR. A stock Euro fuel head might supply enough fuel, but the stock WUR will not deliver. You WILL be running 14.0:1 AFR which will melt that motor in a short amount of time.
The other issue is the IC. Is it big enough to pull the heat out of the charge to reduce the possibility of detonation? What kind of cubic feet will it flow? Big turbos flow a lot of air and since you will tracking the car, you will be blowing a lot of hot air thereby increasing cylinder temps and EGT's.
I am going through the same process as you, however I am going to EFI. I will install 8.0:1 pistons, 3.4L cylinders, stock rods, hybrid 964 cams (higher lift/duration), 3.2L manifold, crank fire ignition, Kokeln IC, custom equal length headers with dual wastegate dump pipes and garrett T61 .71AR turbo. This will replace a CIS motor with a HF turbo that produced a reliable 410rwhp at 1.0 bar. I chose the T61 with a .71 AR because it had the best map for what I wanted - good efficiency to help the Kokeln IC (which flows +900cfm). The T61 will flow 52lbs at 1 bar around 74% efficiency.
If you are interested, there is a turbo calculator available on the web that can help you decide based on numbers. The HF is good to 550 hp and will bolt right up to your headers. More importantly, it was designed for a CIS system and is proven to 450rwhp with similar mods.
Good luck.
strokher racing 10-05-2004 08:33 PM
Beep those headers you posted are the best looking headers I have ever seen! Just messing with you those are my headers:) I am putting a custom 74mm turbo on those bad boys.
Eric Hood
Lensart 10-06-2004 08:17 AM
Eric, did you run a c2 intercooler at one time? Do you think it's going to work on my engine ok? Do you have a k27 hf?
Thanks Randy
beepbeep 10-06-2004 10:02 AM
Thanks Randy
My calcs on your engine:
Volume: 3400cc
Boost: 1 bar
RPM: 6500
Efficiency: 36%
Natural capacity: 95%
Calculated power: 450hp
Calculated mass flow: 35.2lb/min
Fuel flow: 100L/h
Suited injectors (80% duty cycle + 1.2 safety factor): 420cc
Suited turbo: GT30R (just plot it on pressure ratio of 2 and mass flow of 36lb/min and you'll see that you're within 72% efficiency. Raising boost to 1.6 bar will bring you to 45lb/min and you're still on 72% island.
Remeber, you won't be driving at 6000 RPM all the time but accellerating from maybe 4000 RPM. 1 bar @ 4000 RPM means 21lb/min, which would put you quite near surge line on GT35 but will pull good on GT35.
According to my calc, you should be getting sizeable boost already at ~3000 RPM using GT30R. GT35R is optimized to build boost early so it will also build boost almost as quick as GT30R but it will then take some additional revs to bring it to max boost (see the "notch" on surge-line on GT35). GT35 will give you extra power on the top and room to grow but also worse spoolup and bad low-rev response. GT30 will give you very driveable and responsive 450hp engine without breaking a sweat.
Your headers look very good and will work well in this application. On turbocharged cars, equal length headers are of less priority compared to short/heat retaining headers.
I still believe there is power/response to be won by using modern ball-bearing turbocharger. Re-welding of flange shouldn't bee too complicated/expensive.
Good luck!
Lensart 10-06-2004 11:28 AM
Goran, thank you for taking the time to help us. I respect your advice. I see no problem with a new flange. Of course Henry is the builder and I will trust his choice on the turbo and cams. But I like the idea of a modern Garrett and will start looking for a GT30R and see what they cost.
Thanks again, Randy
strokher racing 10-06-2004 05:47 PM
Randy the c2 intercooler is fine for this hp level. Are you going to track the car or street race it? The hf will get you into the power level you are shooting for. Similar combos to yours with less mods have made over 400 at the wheels. Yes I had a hf at one time. depending on future mods would be the deciding factor on the turbo. Let me know if you need any help. I am in Edmond saw you were in Ponca City
Eric
KobaltBlau 10-06-2004 05:55 PM
A guy I know in california bought a GT series from these guys:
http://www.atpturbo.com/
no affiliation, but I think they have some good expertise.
Lensart 10-06-2004 07:12 PM
Thanks Eric, we are going to build a track car for Hallett, remote coilovers, 935 type front and rear, 993 widebody +3, etc. etc. etc. Runing out of money fast! Cory Jump is helping along with Lindsey Racing wheels. My first track car build. I've built a couple of drag cars (back half, tubs, 4 links, etc.) should be fun. This fourm is a great place to get info! (as long as you triple check it. ha!)
We may go EFI next year (if I survive 400hp @ 2200#s) and would like the turbo to handle that, as long as it is not a compromise now.
Thanks Randy
KobaltBlau 10-07-2004 09:26 PM
Holsets have been used on 2.3L gas volvos with success, so I would guess there is an application for a ~3-3.5L gas engine with 911 like flows. I just haven't seen anybody do the compressor map plotting nor have I done it myself.
beepbeep 10-08-2004 05:05 AM
Diesel-rig Holsets have been used on drag-racing engines with sucess. Good thing about them is that they are cheap and flow lot's of air.
Unfortunately, they suffer from same problem as diesel Garrett's: they are built to exact specifications to please truck manufacturers as this is where turbo manufacturers make real money. With other words, A/R's, turbine sizes etc. are made to maximize efficiency and longevity on typical truck engine that revs from maybe 500 RPM to 2000 RPM. They are often very heavy so survive millions of miles.
Those kind of turbos work on gasoline engines and can give lot's of power in certain ranges but they will not provide as good response as race-spec automotive turbochargers.
I have a friend who dynoed 670hp on 2.0L four cylinder engine using Holset HX50 turbocharger, but boost comes quite late.
Engine is SAAB four banger (same as we are using but with shorter stroke) and is currently being installed into BMW Z3 Coupe:
http://forums.pelicanparts.com/uploa...1097236722.jpg
What I'm trying to say is that you can probably get same amount of power from KKK K27 HF or some diesel rig turbocharger but what you cannot get is as good response. So don't just concetrate at achieving vertain power-level but try to make engine driveable troughout the range.
Bietendorf 10-08-2004 08:55 AM
Beep,
From my experience with Holset's on diesel performance mods you are correct with the narrow range of operation. My current HX40 is lazy below 1800 rpm, but will quickly make 2 bar from there to 3000 rpm under load. However, compound turbos are becoming the standard for a wider range of boost from lower RPM, producing up to 4 bar on competition diesels . I have not seen or heard any information on compounding on gas engines, but that does not mean it has been tried. Also, the HX40 has also survived some overtemping above 1400F on several occasions. It is pretty beefy, but not a consideration on a truck. Garrets and shwitzers are getting more popular for diesels, but Holsets seem to be the standard.
I am also curious about the turbo limits in the gas engine. The EGT's are the biggest battle for diesels. Is it pressure, mapping characteristics, or temps that limit turbin applications on the porsche? Also, why not consider compounding turbos for all 6 cylinders for a wider range of mapping? Thanks for helping educate this newbe.
DonE 10-08-2004 01:04 PM
Sounds like you could educate us by thinking outside the box. Compound turbo's, hmmm. Are you referring to multiple or single turbo's?
My considerations when deciding on a turbo for my 930 was mapping (efficiency), pressure (1 bar max) and compressor discharge temp since I am using a smaller intercooler. Using an air-cooled engine with 4 studs holding each head in place, heat and pressure are primary concerns. I have measured EGT's in the 1500 degree range under boost.
Bietendorf 10-08-2004 02:53 PM
Done,
My experience racing motorcycles has been that lap times are reduced exiting corners. This is where the application of power and rubber are critical. I guess I would consider the same issues if I was building a race car. Whatever RPM range your in during a corner exit is important for the proper application of power on an exit. But also, goobs of power are not necessarily good if you can not get it to the ground. In racing motorcycles the saying is sometimes less is more. So, I would consider what the absolute limit of torque your wheels and chasis could could hold on corner exits and build an engine to support that with a little to spare. If that requires compound turbos that would be fine, if not then go single. Races are won and lost on corne exits in otorcycle racing. If you get that nailed everything else usually takes care of itself.
Keep in mind I know nothing about Porsches. I just took delivery of my first 1977 911S this week, found this web sit, and here I am.
Bietendorf 10-09-2004 07:19 AM
Done,
I am hoping your right on the track days for the 911. I raced MX as a kid and moved to road racing latter. Never got my pro card, didnt have enough money to follow the circuit, but did a lot of track days. Anyway, I still have a Ducati.
I am going to the Second Creeck race track near Denver this morning for a local PCA track day. I will not be driving, as I need a tech inspection, but want to see what its all about.
I am interested in the final turbo application on this thread. I would like to know what is chosen, why it was chosen, and did it meet the expectations.
Porschekid962 10-09-2004 11:34 PM
so where are the pics??
