re-ringing a 2.7. hone or not to hone.
I am rebuilding a 2.7. the compression was good on the old engine, but I am going to rering it anyways. should I rough up the cylinders or leave them as is when I rering it? what do ya'll think...
Nickasil or Alusil P&Cs?
nikasil cylinders.
Others may chime in since this is a somewhat controvercial topic. I believe Henry Schmidt at Supertek recommends that you lightly scuff them up with a scotchbrite pad in soap and water. That's what I did when re-ringing my Nickasils. Seems like the rings seated fine.
Others may say to just leave them alone. My exeperience is very limited, but it seems to have worked for me. |
Plenty of food for thought here----
http://forums.pelicanparts.com/911-engine-rebuilding-forum/137346-re-ring-alusils.html |
| All times are GMT -8. The time now is 12:07 PM. |
