Bietendorf
Guest
Posts: n/a
Need 2.7 emissions equipment
Howdy,
Just purchased a well mantained and properly rebuilt 1977 with a 2.7. However, I need some of the emissions parts to pass a visual inspection. They do not need to necessarily work, but I need to install them so they look like they work. Primarily need an air pump and some tubing. The car has a borsche exhaust and header, but I do not think the emissions people really know what the old stock exhaust with thermal equipment should look like, so I am not concerned about that. I also may need to find a used gas canister, but again, this is only a visual inspection and not too concerned they know where to find it. Any suggestions would be appreciated. Also the car has to pass an idle test only, but I am not worried about that as it is tuned very well and this should not be problem. Just need it to look cramped insied with pump and lots of hoses.
Old 10-04-2004, 07:53 AM
Bietendorf
Guest
Posts: n/a
Just reposted this in parts section. Sorry to put in the wrong section. Thanks for being patient to a newby on this board.
Old 10-04-2004, 08:29 AM
The idle test will be affected by the fuel mix.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-09-2004, 08:27 AM
