ausgezeichnet's Avatar
Red face Stubborn Trany Drain Plug
Trying to change my transmission oil today. Started with the fill plug first. Finally managed to get it out (It was a bear!). However the drain plug just won't come out. I've hit it with PB blaster several times and almost popped a vain pulling on it but can't get it to budge. At this point I am going to keep hitting with PB blaster over the next several days. Any other sugesstions? Thanks.
Mike
'84 911 Carrera Coupe (totaled)
'83 911 SC Coupe
‘06 Aston Martin Vantage V8
Old 10-09-2004, 01:18 PM
Got it out! A liitle heat from a hallogen lamp did the trick.
Mike
'83 911 SC Coupe
Old 10-09-2004, 02:04 PM
Nitrometano's Avatar
Put some penetrating oil too.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 10-11-2004, 06:24 PM
Air Medal or two
afterburn 549's Avatar
think torch, thinktorch,, think torch............................................. .................................................. .................................................. .................................................. .............
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 10-13-2004, 11:41 AM
