magic930's Avatar
Oil Cooler Seals?
Should the green engine oil cooler seals be installed dry or with Curil-T or other sealant??
Old 10-28-2004, 07:53 PM
Magic,
Dry is probably OK, but I always put high temp grease (the white stuff) litely on those seals and the oil return tube seals.
Never had a leak/problem.
Tinker
Old 10-28-2004, 08:52 PM
Irrationally exuberant
ChrisBennet's Avatar
A little grease on them helps them stay in place during assembly.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 10-29-2004, 05:02 AM
Slumlord
Porsche_monkey's Avatar
I would use the Dow Corning high temp stuff.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 10-29-2004, 07:16 AM
oneblueyedog's Avatar
I used Silicone grease (not seal) to hold mine in place.
78SC coupe, Silver Metallic
Old 10-31-2004, 05:38 PM
