Send a message via Yahoo to Groovy911SC
SSI installation questions
Which is the best method, installing the SSi heat exchangers on the engine before I put the engine in the car, or after?
Any tips or tricks regarding the oil lines install?
Thanks in advance!
Old 11-02-2004, 06:36 AM
VincentVega's Avatar
It's never easier when the engine is on the stand.
Old 11-02-2004, 07:12 AM
While on stand; especially if you can invert the engine. Beware of the fact that with some engine stands once the SSI's are installed one may not be able to flip it back over - the SSI's hit the engine stand vertical post. Take care that exhaust studs do not protrude too far when using cylinder nuts (Allen nuts) as you can run out of wrenching feature (the end of the stud pushes the hex key out of the nut). This can make future removal very difficult; use a washer(s) under the cylinder nut if stud is too long. Anti-seize lubricant on exhaust manifold studs and on oil line fitting threads but not on oil line fitting spherical sealing surfaces. Cheers, Jim
Old 11-02-2004, 07:45 AM
fancytown
If you have a '72, you need to have the oil line (the one that goes under the case) on first before you install the heat exchangers. Otherwise, like me, you'll have the added experience of also being able to remove, and re-install again when your engine is in the car.
all cars sold.
Old 11-02-2004, 03:35 PM
Friend of Warren
Definitely while on the stand!
Kurt V
Old 11-03-2004, 06:06 AM
Author of "101 Projects"
Wayne 962's Avatar
This statement is not clear. I think you meant:
"It's never easier than when the engine is on the stand."
-Wayne
Old 11-05-2004, 02:29 PM
