-   -   Piston Squirters (http://forums.pelicanparts.com/911-engine-rebuilding-forum/190603-piston-squirters.html)
DonE 11-03-2004 08:18 PM
Piston Squirters
I am cleaning my case one last time before putting it all together and find that I can not blow air through half of them (they seem plugged). Even when I try to run some carb cleaner through the holes, I either get a drip or nothing at all. The others seem fine. I also noticed the small ports seem to be spring loaded??...
3.3L 930 case
Suggestions?
Thx
ChrisBennet 11-04-2004 05:05 AM
Try using a rubber tipped air nozzle if you aren't already. I posted some pictures in this thread: Piston Squirters!
-Chris
Jubbie 11-04-2004 06:18 AM
From the "don't ask me how I know this" files...
You are blowing from the bearing side right?
There is a check valve in there that keeps flow from going from the squirter to the bearing.
DonE 11-04-2004 06:22 AM
Thanks Chris - problem solved.
DonE 11-04-2004 06:29 AM
Thanks John
