-   -   Converting SC motor to a 3.0 930 motor (http://forums.pelicanparts.com/911-engine-rebuilding-forum/190998-converting-sc-motor-3-0-930-motor.html)
Brother 11-05-2004 08:44 PM
Has anyone done this? There seems to be quite a few common parts. Any ideas?
camgrinder 11-06-2004 06:51 PM
Depending on what turbo you run the compression ratio may be too high.
The nice part is the SC cams work nice with most turbos.
Brother 11-06-2004 08:30 PM
could you just substitute the 930 exhaust and intercooler on top of the existing CIS and just make it a very low boost car. I already have 8.5:1 pistons so I'm sure it could take up to at least .8 bar on the good stuff.
camgrinder 11-06-2004 08:42 PM
Sounds good to me. You can also regrind the SC cams to 964 specs, this will reduce the cylinder pressure a little and help with the 8.5-1 C/R.
john walker's workshop 11-07-2004 09:22 AM
that's the base engine in my 77 930. case crank and rods from a '79 SC, and 930 P+Cs, heads, intake and exhaust. i didn't have a early 930/carerra aluminum case at the time, but i had all the other stuff.
Brother 11-07-2004 09:31 AM
so basically everything that I would replace on a rebuild anyway plus an early 930 exhaust. Are the heads that I have good or do they need to be a special 930 part?
Are you running an intercooler?
I was somewhat interested in replacing the CIS as well. Is there any clean way to do this and turbo as well?
BTW - John, I think this car used to be maintained by your shop. I bought it from a guy in Rainier about 3 months ago. I have all the records from purchase on. It has been in the seattle/olympia/tacoma area its whole life until now.
RarlyL8 11-09-2004 07:34 PM
Richard Fong makes a turbo kit for the 3.0L SC engine. That might be the best way to go.
iamchappy 11-10-2004 08:21 AM
Start looking for a used BAE kit, if your on a budget.
http://forums.pelicanparts.com/showthread.php?s=&threadid=90065&perpage=20&pagenu mber=1
Brother 11-10-2004 03:06 PM
gimme a website for Richard Fong
RarlyL8 11-17-2004 07:35 PM
Don't know the site name. Doing a search using "rfng" should get you the info.
Brother 11-17-2004 07:41 PM
Thanks.
