Brother's Avatar
Converting SC motor to a 3.0 930 motor
Has anyone done this? There seems to be quite a few common parts. Any ideas?
Paul
1980 911SC Targa - Sold
1972 914 - Sold
Old 11-05-2004, 08:44 PM
camgrinder's Avatar
Depending on what turbo you run the compression ratio may be too high.
The nice part is the SC cams work nice with most turbos.
John Dougherty
Dougherty Racing Cams
Old 11-06-2004, 06:51 PM
Brother's Avatar
could you just substitute the 930 exhaust and intercooler on top of the existing CIS and just make it a very low boost car. I already have 8.5:1 pistons so I'm sure it could take up to at least .8 bar on the good stuff.
Paul
1972 914 - Sold
Old 11-06-2004, 08:30 PM
camgrinder's Avatar
Sounds good to me. You can also regrind the SC cams to 964 specs, this will reduce the cylinder pressure a little and help with the 8.5-1 C/R.
John Dougherty
Old 11-06-2004, 08:42 PM
that's the base engine in my 77 930. case crank and rods from a '79 SC, and 930 P+Cs, heads, intake and exhaust. i didn't have a early 930/carerra aluminum case at the time, but i had all the other stuff.
206 637 4071
Old 11-07-2004, 09:22 AM
Brother's Avatar
so basically everything that I would replace on a rebuild anyway plus an early 930 exhaust. Are the heads that I have good or do they need to be a special 930 part?
Are you running an intercooler?
I was somewhat interested in replacing the CIS as well. Is there any clean way to do this and turbo as well?
BTW - John, I think this car used to be maintained by your shop. I bought it from a guy in Rainier about 3 months ago. I have all the records from purchase on. It has been in the seattle/olympia/tacoma area its whole life until now.
Paul
1972 914 - Sold
Old 11-07-2004, 09:31 AM
Crotchety Old Bastard
RarlyL8's Avatar
Richard Fong makes a turbo kit for the 3.0L SC engine. That might be the best way to go.
Old 11-09-2004, 07:34 PM
iamchappy's Avatar
Start looking for a used BAE kit, if your on a budget.
911SC Turbo
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 11-10-2004, 08:21 AM
Brother's Avatar
gimme a website for Richard Fong
Paul
1972 914 - Sold
Old 11-10-2004, 03:06 PM
RarlyL8's Avatar
Don't know the site name. Doing a search using "rfng" should get you the info.
Old 11-17-2004, 07:35 PM
Brother's Avatar
Thanks.
Paul
1972 914 - Sold
Old 11-17-2004, 07:41 PM
