getting started
Hi guys, just getting started on my first rebuild. Motor drop with no problems and down to the long block now. Hope to have it totally disassembled by the weekend. Wish me luck.
Thanks to Paul Harper (PHB) and Mike Dunn for the use of special tools and motor stand.
picture attached I hope
Joe
Old 11-11-2004, 06:51 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Looks like a good start. It looks like you're working on 73T motor, any upgrades planned?
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 11-12-2004, 05:10 AM
Bandwidth AbUser
Jim Richards's Avatar
I'm in the same boat, Joe. My 73E engine is disassembled and I'll be sending parts out soon to be machined. BTW, nice looking targa.
Jim R.
Old 11-12-2004, 05:18 AM
Tim, the plan is to put it back togethor stock at this point. If it needs pistions I may go higher compression and see where that takes me. I will need a new set of SSIs and a muffler TBD.
Thanks, Joe
Old 11-12-2004, 05:56 AM
Why is is that when I look at a Porsche engine out of a car, I can't help but admire it. Good luck and enjoy. And, document, document, document.
Michael
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 11-12-2004, 09:02 AM
I just got a 1974 Targa and plan to start the same shortly. One question, how did you get the engine from the jack, assuming, up to the engine stan? Thanks.
Tom
Old 11-12-2004, 04:11 PM
Invite 3 or 4 friends over. That's how I did it.
1997 BMW M3 (Hail)
1985 928 S (Sold)
Old 11-12-2004, 04:30 PM
No Expert
jgparker's Avatar
Looks good Joe. Good luck on the rebuild.
Tom,
You can use a high lift jack and a two leg engine stand to get the engine on the stand. The only other choices I know of are a crain or a lot of friends. I don't have either of them, so I use the jack.
Good luck,
JP
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 11-13-2004, 05:21 AM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Re: getting started
[QUOTE]Originally posted by TargaT
[B]Hi guys, just getting started on my first rebuild. Motor drop with no problems and down to the long block now. Hope to have it totally disassembled by the weekend. Wish me luck.
QUOTE]
Joe, you will have alot of enjoyment from the whole process. I went from this:
to this in a span of about 8 weeks:
Take your time and document the highs and lows of the process.
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 11-13-2004, 02:28 PM
Throughly clean (and I mean completely clean out all oil and grit) the rocker arm shaft bores in the cam towers before removing the rocker arm shafts. Do not mar the bores removing the rocker arm shafts. Tag and bag everything; take notes and images if you can.
73.5T engine (black painted 73TMFI shroud) before:
73.5T engine and transmission after:
Jim
Old 11-15-2004, 08:12 PM
