ARP Head Torque
Does anyone have the torque values for their head stud kit?
This is for a 930 rebuild. Thx |
It's 42 ft-lbs with oil or 36 ft-lbs with ARP moly lube. That's right off my box of ARP studs awaiting installation.
Make sure you follow their instructions carefully. It sounds like you don't have a copy of them - contact them and request one...
-Wayne |
Ralph |
I spoke to ARP and they also said not to forget to lube the washers, and cycle the nuts 3 - 5 times. This "breaks them in".
do you use locktite on arp studs or? when installing them in the block
I put oil on the case end of the stud.
Ralph |
Don, I sent you a PM.
| All times are GMT -8. The time now is 12:56 AM. |
