Wo ist die Rennstrecke?
DonE's Avatar
ARP Head Torque
Does anyone have the torque values for their head stud kit?
This is for a 930 rebuild. Thx
Old 11-16-2004, 06:01 PM
David's Avatar
It's 42 ft-lbs with oil or 36 ft-lbs with ARP moly lube. That's right off my box of ARP studs awaiting installation.
Old 11-16-2004, 06:16 PM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
36 ft/lbs with ARP moly lube is exactly what I just did per their instructions.
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 11-17-2004, 06:41 PM
DonE's Avatar
I spoke to ARP and they also said not to forget to lube the washers, and cycle the nuts 3 - 5 times. This "breaks them in".
Old 11-17-2004, 08:14 PM
do you use locktite on arp studs or? when installing them in the block
1983 911SC
1977 911S "parting out"
Old 11-18-2004, 12:51 AM
David's Avatar
I put oil on the case end of the stud.
Old 11-18-2004, 04:07 AM
I used Loctite 262 when threading them in the case. I would chase the threads first.
Ralph
Old 11-18-2004, 06:08 AM
David's Avatar
Don, I sent you a PM.
Old 11-18-2004, 04:44 PM
